2 front 2 rear injectors not working
Old 04-23-2011, 08:50 AM
crichf
crichf is offline
crichf is starting off with a positive reputation.
I have a 1992 Ford F-150, pushing 250,000 miles, V8 (302). Just recently the two front and two rear fuel injectors quit working. They are not getting signal to turn on. I'm guessing computer problems. Does this sound right, or could there be other issues?
Old 04-23-2011, 08:56 AM
EPNCSU2006's Avatar
EPNCSU2006
EPNCSU2006 is offline
EPNCSU2006 has a great reputation on FTE.EPNCSU2006 has a great reputation on FTE.EPNCSU2006 has a great reputation on FTE.EPNCSU2006 has a great reputation on FTE.
Those four injectors are controlled by the same circuit from the computer, so it sounds like there is a break in the wire somewhere between the engine and the computer. To start with, I would check continuity between the injector(s) and the computer. If there is no continuity, the circuit is broken somewhere inbetween so you will have to trace the wire and fix the break. If there is good continuity to the computer, the problem could be the injector driver in the computer itself.
Old 04-23-2011, 09:56 AM
rla2005's Avatar
rla2005
rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
I agree it is most likely a wiring problem. Use this for reference:
Courtesy of FordFuelInjection.com
helpmytruk
07-18-2014 11:40 AM
tobyw
Modular V10 (6.8l)
11-11-2013 10:24 AM
catman52987
01-29-2012 10:37 PM
hcman70
11-16-2009 05:00 PM
KevinC.
15
05-11-2009 11:12 AM
Quick Reply: 2 front 2 rear injectors not working
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
