so the needle on my speedo bounced kinda bad around 50 60 70and it wouldnt let me use cruise so i pruchesed a new one from napa. vss319. The new ones plastic old ones metal i replaced it and it now bounces anyware above 10 or 20. So today i tore the diff cover off cleaned all the crap out of the dif put new fluid it and now i think its actully worse any help or ideas?
PSOM Pointer Waiver TSB 96-21-11 by Ford for 92-96
Programmable Speedometer/Odometer Module Pointer Waiver Article No. 96-21-11
ISSUE: The speedometer needle may waver and/or a light surge may occur on some vehicles when speed control is used
at highway speeds between 80-113 km/h (50-70 mph). This may be due to slight dents/chips in either the exciter ring
or the Vehicle Speed Sensor (VSS) and air gaps between the VSS and the exciter ring.
ACTION: Replace the Programmable Speedometer/Odometer Module (PSOM) if required. New PSOM's come with increased immunity to system
variability. Refer to the following Diagnostic Procedure for details.
DIAGNOSTIC PROCEDURE
BRONCO/F-SERIES - Perform normal PSOM diagnostics per Pinpoint Tests "H" and "J" of the 1996 F-Series/Bronco
Body/Chassis Service Manual, Pages 13-01-30 through 13-01-32 and Pinpoint "B" of the 1996 Powertrain/Drivetrain Service Manual,
Page 10-03-11.
1. Any slight dents, chips, etc., in either the exciter ring or VSS will create needle waver. Measure air gap between
the VSS and exciter ring. It should be 0.38-0.51 mm (0.015-0.020").
2. Check exciter ring runout per the same ring gear backface runout procedure of the appropriate model 1996
Powertrain/Drivetrain Service Manual, Section 05-00. Make sure the exciter ring is mounted correctly to the
ring gear. If runout is more than 0.1 mm (0.004"), perform the differential runout check per the procedure in the
appropriate model 1996 Powertrain/Drivetrain Service Manual, Section 05-02A or 05-02D, to find cause and repair as needed.
3. If all items listed above check good, replace the Instrument Cluster Assembly. Obtain the correct service part number from the Parts Catalogue
and then contact the Electronic Odometer Exchange Center at (800) 259-9700 for U.S. Dealers and (800) 663-9974 for Canadian Dealers.
NOTE: DEALERSHIP MUST TELL THE ODOMETER EXCHANGE CENTER THAT YOU NEED A PSOM3 LEVEL CLUSTER FOR A SPEEDOMETER NEEDLE WAVER CONCERN.
OTHER APPLICABLE ARTICLES: NONE
WARRANTY STATUS: Eligible Under The Provisions Of Bumper To Bumper Warranty Coverage
Bronco 962111B Replace Programmable 0.7 Hr.
BASIC PART NO. CODE 10849 06
OASIS CODES: 204000, 204100, 204200, 205000
#2 in Ricks post above is the most common reasons I've seen for a bouncing speedo. It doesn't take much to knock it out of tolerance, (.004"). Look through the sensor hole vs. removing the cover again to check it.
I've only seen this 2 times & both times it was from rust build up under the sensor . If the tone ring is screwed up , there may be a really good (bad ) reason for it ...
