Want a TALL liftgate? Forget 4x2 lift supports. - Page 20 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
Reload this Page >
  #286
Old 01-05-2016, 05:10 PM
DidieX
DidieX is offline
DidieX is a name known to allDidieX is a name known to allDidieX is a name known to allDidieX is a name known to allDidieX is a name known to allDidieX is a name known to all
Originally Posted by USCG_PA View Post
My new ones act exactly the same way. However, before I replaced them, the cold air sapped the strength right out of the old ones...
Originally Posted by harley4jcs View Post
The update on mine would be: In the Summer, STAND BACK & hang on to the door. In the Winter pop the hatch & wait 2 sec then the hatch will lift itself ALL the way up on it's own.
Thanks for the info. Have you had them for a while now or did you just recently install the replacements?
  #287
Old 01-05-2016, 05:15 PM
USCG_PA's Avatar
USCG_PA
USCG_PA is offline
Baba Yaga
USCG_PA has a superb reputationUSCG_PA has a superb reputationUSCG_PA has a superb reputationUSCG_PA has a superb reputationUSCG_PA has a superb reputationUSCG_PA has a superb reputationUSCG_PA has a superb reputationUSCG_PA has a superb reputationUSCG_PA has a superb reputationUSCG_PA has a superb reputationUSCG_PA has a superb reputation
  #288
Old 01-05-2016, 07:34 PM
Nicmike's Avatar
Nicmike
Nicmike is offline
Veteran/Sheepdog
Nicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputationNicmike has a superb reputation
Originally Posted by DidieX View Post
Are you using originals or the ones from lift support depot? Are they new or old? I'm trying to gauge the life of the ones from lift support depot. I open the hatch A LOT and I don't want to be replacing them every winter.
My Lift Support Depot parts have been on for about 3 years (at least), and I am only just now having problems with them opening the hatch in winter. Before, it was like someone else said, "you better hang on". I will wait till it warms back up and decide if I am going to replace. It does stay open when I help it up. I still have to pull on it pretty good to get it closed, so I think it just may be the cold weather on opening (which we don't get a lot of down here).
  #289
Old 01-05-2016, 08:12 PM
DidieX
DidieX is offline
I guess 3 years is reasonable. The ones I have now seem to have been replaced by the po with the standard sized ones, the labels on them look almost new, and they're sagging a lot in the cold. They were never "you better hang on" strong. Always have to give it a little push when it gets to almost fully open. But now with the cold weather here (finally!), I have to help them all the way from fully closed. It gets tiring really fast when you need to keep going back to the truck at least 2 dozen times a day for tools/materials. Guess I'll be ordering a set of these extra tall ones. Thanks for all the input!
  #290
Old 01-05-2016, 08:49 PM
Misky6.0's Avatar
Misky6.0
Misky6.0 is offline
Misky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputation
Same with me. Morning temps in upper 40s, yes I am lucky. Opened my rear yesterday to pull out the winter front and noticed my 2 or 3 year old liftsupport struts didn't have the same superpower. They did lift it all the way, once I got it moving..
  #291
Old 01-06-2016, 12:06 AM
harley4jcs's Avatar
harley4jcs
harley4jcs is offline
harley4jcs has a great reputation on FTE.harley4jcs has a great reputation on FTE.harley4jcs has a great reputation on FTE.harley4jcs has a great reputation on FTE.harley4jcs has a great reputation on FTE.harley4jcs has a great reputation on FTE.
The ones I've posted about are just about a year old now.
  #292
Old 02-17-2016, 08:46 AM
Elmo154
Elmo154 is offline
Elmo154 is gaining momentum as a positive member of FTE.
Good price on rear window struts (free shipping)
Just ordered these from Amazon:
Estimated delivery: Feb. 29, 2016 - Mar. 10, 2016
ARANA New 2 Rear Window Glass Gas LiftSupports Springs Struts arm for Ford Excursion 2000-2005 1.5" Higher ThenOEM
$19.99
Quantity: 1 Change quantityof ARANA New 2 Rear Window Glass Gas Lift Supports Springs Struts arm for FordExcursion 2000-2005 1.5" Higher Then OEM from 1 Update quantityof ARANA New 2 Rear Window Glass Gas Lift Supports Springs Struts arm for FordExcursion 2000-2005 1.5" Higher Then OEM from 1 | Delete ARANA New2 Rear Window Glass Gas Lift Supports Springs Struts arm for Ford Excursion2000-2005 1.5" Higher Then OEM
We're sorry. Thequantity you have entered is not valid. Please enter a quantity between 0 and999. We're sorry. This item has limited purchasequantity. We have changed your purchase quantity to the maximum allowable.We're sorry. The quantity you requestedexceeds what is currently available. The quantity has been updated to themaximum quantity currently available. please input correct qty base on Product Bundle item Sorry, the quantity you requested is notavailable right now. We did not update your quantity.
Sold by: ARANA Lift Support
Gift options not available
  #293
Old 02-17-2016, 08:58 AM
harley4jcs's Avatar
harley4jcs
From your post i'm not sure you will be getting those
  #294
Old 02-17-2016, 09:16 AM
Elmo154
Elmo154 is offline
Oops!
Good catch. The order confirmation says they are shipping and does not have they rejection that you pointed out. I guess we will see.
Thanks!
  #295
Old 12-29-2018, 06:48 PM
aklim's Avatar
aklim
aklim is offline
aklim has a very good reputation on FTE.aklim has a very good reputation on FTE.aklim has a very good reputation on FTE.
I'm looking at the Autozone ones for the 4X2.
Mighty Lift E95302.
Extends to: 14.72,
Min Force: 134.5
Max Force: 149.5
Sachs SG304046
Extends to: 14.72
Min Force: Assumed to be similar
Max Force: Assumed to be similar
Using ARANA brand Part # 6421EX ,15.87 which is mentioned here, it cross references to a Sachs SG301026 based on THIS link. The Sachs lists a force of 117 which is below the Mighty Lift spec of 134 for min and 150 for max. Anyone have any idea if the min and max force mean anything in this case and what it means? I am liking the Sachs since I can order it from the local Autozone, which is everywhere at a small discount and I can get warranty anywhere there is an Autozone since it is lifetime. Any help?
  #296
Old 12-30-2018, 02:43 AM
Skip1970's Avatar
Skip1970
Skip1970 is offline
Skip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputation
i dont know but mine are sucking again, now that its cold i dont feel very confident the will keep it up as it feel week
salazar44
1997-2006 Expedition & Navigator
05-13-2017 01:14 AM
salazar44
01-10-2017 01:02 AM
Navigator777
10-30-2016 01:04 PM
Wealthk1
2017+ Super Duty
13
09-02-2016 06:16 PM
Ausm7499
05-15-2016 11:36 PM
Quick Reply: Want a TALL liftgate? Forget 4x2 lift supports.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
