Want a TALL liftgate? Forget 4x2 lift supports. - Page 15 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
Reload this Page >
  #211
Old 11-25-2014, 12:24 PM
Apocalypse's Avatar
Apocalypse
Apocalypse is offline
Apocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputationApocalypse has a superb reputation
Originally Posted by David - WI View Post
No, actually I put them in upside down so they wouldn't get bent when the gate opens & closes.
There's your problem, they go sideways Seriously though, that's not normal. Contact the company and get a replacement set. This is one of the best mods for the X and you shouldn't be this unhappy with it.
  #212
Old 11-25-2014, 12:51 PM
Skip1970's Avatar
Skip1970
Skip1970 is offline
Skip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputation
Originally Posted by Immortal_Ben View Post
Take the handle off
im still not sure why there is a handle? i close it from the ouside. wouldnt wanna get my arm jammed in there.
  #213
Old 11-25-2014, 02:13 PM
Immortal_Ben's Avatar
Immortal_Ben
Immortal_Ben is offline
Immortal_Ben has much to be proud ofImmortal_Ben has much to be proud ofImmortal_Ben has much to be proud ofImmortal_Ben has much to be proud ofImmortal_Ben has much to be proud ofImmortal_Ben has much to be proud ofImmortal_Ben has much to be proud ofImmortal_Ben has much to be proud ofImmortal_Ben has much to be proud of
The handle is there for short people to reach, or to close the hatch from inside. Or for those who really lift their truck!
  #214
Old 11-25-2014, 02:29 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
The Nekkid Super Mod
Stewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputationStewart_H has a superb reputation
The extended ones don't work all that great on mine. I have to physically lift the hatch almost all the way up or it only opens part way... and it takes a lot more effort to close it.
I wonder if you got the correct set for Excursions.
Stewart
  #215
Old 11-25-2014, 08:55 PM
Misky6.0's Avatar
Misky6.0
Misky6.0 is offline
Misky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputationMisky6.0 has a superb reputation
Originally Posted by Krazee Matt View Post
It's nice being able to close it from the inside.
But you can't open it from inside?? That would be a great mod!
  #216
Old 11-25-2014, 09:22 PM
Krazee Matt's Avatar
Krazee Matt
Krazee Matt is offline
Leadfoot
Krazee Matt has a superb reputationKrazee Matt has a superb reputationKrazee Matt has a superb reputationKrazee Matt has a superb reputationKrazee Matt has a superb reputationKrazee Matt has a superb reputationKrazee Matt has a superb reputationKrazee Matt has a superb reputationKrazee Matt has a superb reputationKrazee Matt has a superb reputationKrazee Matt has a superb reputation
Indeed it would! Hmm...
  #217
Old 11-26-2014, 12:38 PM
David - WI
David - WI is offline
David - WI is gaining momentum as a positive member of FTE.
Stewart
Supposed to be, they came from LSD's EBay store (eBay item number:231172316523 +1.5" lift for Excursion) but I'll try soaking the hinges with lube first.
They aren't horrible, they just don't work as well as the ones that were on it when I got it... no idea if they were original or not though.
  #218
Old 12-02-2014, 10:08 PM
aaedin's Avatar
aaedin
aaedin is offline
aaedin is gaining momentum as a positive member of FTE.aaedin is gaining momentum as a positive member of FTE.
(Upper picture is the stock lifts, lower picture is the new 4x2 lifts.)
There were before and after pictures from a lot of members with stock lifts before and the extended TALL lifts talked about in the beginning of the thread after. Here are before and after shots of the stock vs the 4x2 lifts. I was worried that the extended tall ones would be just a little too big for my little lady, shes 5'6''. (Although the extended lifts do look awesome.) My Ex has stock tires and no lift just for reference. On my Ex, I measured with a tape measure and the stock lifts lifted the liftgate so that it was 72 inches high. Measured to the bottom of the gate right where the inside handle is located. With the 4x2 installed, I got 76 inches of height under the gate. Also a plus is that I have full extension, with little force from myself after unlatching the gate. With the stock, it was only raising it up to about 66 inches of clearance. The old lifts had lost their mojo to say the least. So there you go, 72 inches up to 76. Who knew 4 inches would make all the difference? (Yup, I set that one up.)
  #219
Old 12-02-2014, 10:20 PM
fire240's Avatar
fire240
fire240 is offline
fire240 has a superb reputationfire240 has a superb reputationfire240 has a superb reputationfire240 has a superb reputationfire240 has a superb reputationfire240 has a superb reputationfire240 has a superb reputationfire240 has a superb reputationfire240 has a superb reputationfire240 has a superb reputationfire240 has a superb reputation
Looks good Robert.
  #220
Old 12-03-2014, 07:57 AM
David - WI
Mine opens (slowly) to 76" ground-to-inside-handle, more or less on it's own after I get it halfway up... and then to 81" if I lift it the rest of the way.
  #221
Old 01-18-2015, 10:54 AM
crazytwo
crazytwo is offline
crazytwo has a very good reputation on FTE.crazytwo has a very good reputation on FTE.crazytwo has a very good reputation on FTE.crazytwo has a very good reputation on FTE.
After 15 years and 190k miles, it is time to replace my original struts. This thread started almost 4 years ago. I am curious how the struts that were replaced have held up? Have any failed. If so, how long did they last.
  #222
Old 01-18-2015, 12:45 PM
white Buffalo's Avatar
white Buffalo
white Buffalo is offline
white Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud ofwhite Buffalo has much to be proud of
Have had mine for almost 4 years, no problems. Wouldn't hesitate to buy them again....
  #223
Old 02-23-2015, 08:44 AM
Magnus E's Avatar
Magnus E
Magnus E is online now
Magnus E has much to be proud ofMagnus E has much to be proud ofMagnus E has much to be proud ofMagnus E has much to be proud ofMagnus E has much to be proud ofMagnus E has much to be proud ofMagnus E has much to be proud ofMagnus E has much to be proud ofMagnus E has much to be proud ofMagnus E has much to be proud of
I did this mod about a year ago - very happy. I have noticed though that when cold (20s and colder) the lift supports weaken and barely hold the gate up. Anyone else have the same experience? If not, mine might be defective and need replacing.
  #224
Old 02-23-2015, 02:38 PM
tnexcusion
tnexcusion is offline
tnexcusion is starting off with a positive reputation.
Looking at replacing mine. Have a 4x4 but really need it higher. I am 6'4" and the ones I have now suck. I went to the site and they list a few different ones. Which ones you guys suggest?
  #225
Old 02-23-2015, 02:41 PM
SVTDarin's Avatar
SVTDarin
SVTDarin is offline
SVTDarin has a good reputation on FTE.SVTDarin has a good reputation on FTE.
I am also 6'4" and these work great.
Amazon.com: Qty (2) Ford Excursion 2000 2001 2002 2003 2004 2005 Rear Window Lift Supports with 1.5" higher opening for tall person: Automotive Amazon.com: Qty (2) Ford Excursion 2000 2001 2002 2003 2004 2005 Rear Window Lift Supports with 1.5" higher opening for tall person: Automotive
Quick Reply: Want a TALL liftgate? Forget 4x2 lift supports.
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
