460 exhaust upgrades
Well...its time. I've got a good running stock 460 from a '77 Grand Marquie I'm gonna swap for the 400 in my '79 F 350 4X4. I have some long term plans for the motor but for the time being (next 5 yrs) i don't have the time and money to do it all.
It leaks so I'm gonna replace all the gaskets and remove the heads so I can remove those damn mountainous humps in the exhaust ports. I'll also replace the timing chain and main/rod bearings and add a high volume oil pump.
I plan to use an earlier timing chain ('71?) to "stand up" the valve timing. Is this correct? I also have plans for headers but will probably use some truck manifolds for now. Given the truck manifolds maximum performance, would I even gain anything by porting the exhaust ports?
Although I have a Holley 750 double pumper, I am leaning towards keeping the stock carb for the time being. I have used the Holley on a previous 460 build and removed it. It was WAY to much carb even for all the heavey mods I did.
Any suggestions would be greatly appreciated. Thank you.
brooklyn
26
11-09-2023 11:21 AM
compman
12-22-2013 09:23 PM
mark460
08-03-2009 04:58 PM
86rustbucket
04-04-2007 01:42 AM
Wishbone
02-25-2003 05:43 PM
