best 35x12.50x20 AT tire
I just had this same conversation, at length, with my buddy who was looking for tires for his '08 F350...
Do NOT put 12.5 tires on a stock (8 inch wide) wheel. They are NOT the proper size, period. It doesn't matter how many people do it, that doesn't mean they're the right fit...sorry.
Just about every tire manufacturer has a "recommended rim/wheel width" specification on their website, and I couldn't fit a single one that recommended a 12.5 inch tire for an 8 inch rim.
Why does it matter? You may get it to fit (as obviously a whole lot of other people have) and it may look right, but you don't need to be a tire engineer to figure out you're putting a whole lot of sidewall stress on the tire by fitting it on a wheel that's too narrow. And if you tow (as I do with my '10 F250 and he does with his truck) you could be asking for all sorts of trouble.
That's definitely trouble he doesn't need, and although it seems a whole lot of tire shops don't seem to mind that they're fitting the wrong size tire on a rim they sure would care if there was a catastrophic malfunction/failure followed by a wreck...or worse...
That's when the "I read it was OK to do it on the internet" excuse would fall real short in a court, etc.
What did he end up with? Toyo Open Country A/T 285/75 R18 which, coincidentally, are double marked as 35x11.5 R18. The Open Country M/Ts are also available in the same size, and both tires are Load Range E rated, as they should be...
Hope this helps...
Running the Goodyear ATs, have not experienced annoying level of road noise (subjective), and at about 15K miles they seem to be about half used-up. I have not priced replacement, but a local tire dealer estimated $240/tire. They are load range E and have held up when hauling about 2400 lb pin weight with 80psi. I will buy them again.
STGFordCrazy04
06-19-2006 08:37 PM
