Another Vin Decode Question
E10 = E100 Pickup.
T = 170 1V I-6.
H = Lorain OH Assembly Plant.
254568 = 1962, assembled January 1962.
90" Wheelbase.
J = Rangoon Red.
E104 = E100 Pickup, 4,350 lbs. GVWR
A = Ford 3 Speed Light Duty Manual Transmission.
01 = Ford WCC-A 7 1/4" Rear Axle / 3.50-1 / 2,300 lb. Rear Axle Capacity.
4,350 lbs. Gross Vehicle Weight Rating.
85 net HP @ 3,600 RPM
on
Quote:
Originally Posted by 76f350spercamprspeal
Welcome to FTE, Best Damn Forum EVER!
Here's How to Post Pictures:
1. Login to FTE.
2.Click User CP (In the Top Left Hand Corner)
3.(On the Left, There will be a list, The 5th Option Down, will say "Pictures & Albums) Click That.
4.Then, Click Add Album, Enter a title, and description, if ya want to.
5. Click Upload Pictures, Then click Browse, Locate the Files of your truck. (You can add 3 files at a time)
5. Click Upload.
6. Add a description to the individual pictures, then click save.
7. Add more files if ya want.
8. Click The Picture you want to post, it will give you two codes at the bottom, Right Click The Second one (It say's BB Code, Then Say's [IMG]http:blahblahblah...[/IMG])
Then, Once that is highlighted, Right Click, Then Copy, Then Paste it into your post.
You can add up to 30 Images in one FTE Post.
If, Ya need any help, Don't hesitate to ask.
1. Login to FTE.
5. Click Upload.
