F 150 BACKFIRING
Old 04-18-2011, 06:10 PM
theendresult's Avatar
theendresult
theendresult is offline
F 150 BACKFIRING
Hey,
My buddy has a 91 f150 that is back firing like crazy when under load. Idling its fine. From what he told me he changed the distributor cap and didn't label the wires. So he probably mixed them up when putting them back on. How does one go about figuring out which wire goes where? Thanks for the help!
Old 04-18-2011, 08:29 PM
Elderstarr's Avatar
Elderstarr
Elderstarr is offline
first off... which engine?
Firing Orders for Ford Engines
Old 04-18-2011, 08:30 PM
timbersteel's Avatar
timbersteel
timbersteel is offline
What size motor?
Also, is the motor stock?
Let us know and we can give you the firing order.
Old 04-18-2011, 08:32 PM
timbersteel
Thanks for posting the link Elderstarr. I'll have to bookmark that!
Old 04-18-2011, 09:25 PM
theendresult
Originally Posted by timbersteel
What size motor?
Its a stock 302 out of a 1992 truck
Old 04-18-2011, 09:32 PM
theendresult
I just heard back from him and he got a diagram and hes pretty sure its all correct but it still backfires. Any ideas?
Old 04-18-2011, 10:01 PM
timbersteel
ok, just be sure he has the corect diagram for the '94 and earlier 302's. '95 and later used a different one.
Can you give any history on the truck from your buddy? like when did the backfiring begin? Is there a CEL on in the DASH? Hsa he pulled code? There maybe some codes stored and the CEL doesn't necessarily have to be on show signs of a problem(s).
If it's running fine @ idle and then begins backfiring, there could be any number of things wrong. Checkvalves for the Thermactor/Smog System. Fuel pump on the way out. Bad MAP sensor.
Checking fuel pressure would be a good idea.
What Plugs is he using? (Platinums, Bosch, and High dollar plugs will NOT do you any good and cause more problems than good!) Stick with regular motocraft or autolites!!
What plug gap is he running?
Does he have the plug wires for 7 and 8 separated? (These 2 cylinders cause Crossfire) Be sure and separate them.
Let us know and will chime back!
EDIT: After re-reading the statement" My buddy has a 91 f150 that is back firing like crazy when under load. Idling its fine." tells me the firing order is correct. If the firing order was wrong, it would run like crap from the start. He needs to check my lists of possible other problems. If he doesn't know how to pull codes, you can do it for free with a jumper wire and a meter. Go to www.fordfuelinjection.com. Have a read there.
Old 04-18-2011, 10:06 PM
Elderstarr's Avatar
Elderstarr
Do you know if it stared before or after your friend changed the cap?
If it started exactly after he changed the distributor cap, I could see no other possibility why it would be backfiring... unless he got some water in it.
Other possibilities...
Timing chain skipped a tooth
camshaft has the H.O. firing order
Bent/unseated valve
does the engine shake heavily at idle?
Old 04-18-2011, 11:11 PM
theendresult
Bent/unseated valve
It started happening after he changed the cap and mixed up the leads. Its a new distributor cap.
The engine shakes but I dont think its anything out of the ordinary
Ill let him know and see what he says. Thanks for the input guys
Old 04-22-2011, 10:15 PM
PeterSr's Avatar
PeterSr
PeterSr is offline
Originally Posted by theendresult
Hey,
After checking spark plug wire routing, make sure that the base idle timing is also checked.
tazzmann01
29
03-01-2020 07:15 PM
campingshadow
1997 - 2003 F150
06-22-2017 08:45 PM
rickula
1997 - 2003 F150
11-03-2011 11:02 AM
asfitch
2004 - 2008 F150
12-19-2010 10:31 PM
Greg 79 f150
25
05-16-2005 04:24 PM
Quick Reply: F 150 BACKFIRING
