Mud drag this summer. Tire size?
I'm going to enter my 77 f150 in a mud drag (or bog, whatever you want to call it) this coming summer. by then, the 400 will be dropped in and will have an rv cam. I'm running 33's on it right now and I have a set of 33" Regul's to put on it. There's different tire classes for the bog, so I was just curious, what's the largest tire I can run on a stock high pinion dana 44 and not blow out the diff or blow a shaft on the launch? Keep in mind, I'll probably be doing more than one launch.
I ran 35x11.5x15 Boggers on my Bronco mud bog truck for 3 years with a Dana 44 with no problems. It was an '86 with the ttb and it held up fine. We had a little tire rub but not too bad so I didn't worry about it for the first 2 years. We never drove it on the street so if the fenders got beat up a little it didn't matter. Last year I put a 3 inch body lift on it and that fixed any rubbing problems we had.
Then the Bronco died. Got $100.00 for it at the scrap yard.
6ohman2004
01-18-2014 07:12 AM
jlc84cam350
09-24-2011 12:31 AM
