AC Clutch acting strange?
I replaced the orings in my hpop today and all seems well with the oil pump and everything I worked on. I do have a question for everyone. The clutch on my AC compressor is now popping in and out every 10 to 15 seconds. Did I miss something or not connect it right? Any thoughts?
As an aside, I found that a 1/4" drive 10mm deep socket does a great job accessing the bolt by the IPR valve.
Here is a good write up that explains how to check the air gap and the fix. Check out the fifth photo down the page which shows where the shim is located.
http://www.springerpop.net/F350/air_gap.html
