getting a weird vibration
I have a '03 6.0 PSD.. Every now and then when i crank it up and let it sit for a minute or so it starts acting like it is losing fuel and wants to die. It never shuts off just seems like it wants to. And if you are inside the truck ist starts vibrating pretty bad..enough to shake the cab. IF anyone can help i would greatly appreciate it. Thanks alot Todd
There is a known issue with bad injector O seals. Check your oil level. If there is an injector problem then diesel is being added to the oil. If the engine was built before Feb 01 then there is a part to be changed as well as a computer reflash. I'm a total newbie with diesels as well as this motor.
Fred
Fred
