It's not WVO, it's not B100- what the hell is it?
I gotta local guy on Craigslist that sells "biofuel". He told me it's WVO cleaned/dewatered, and he thins it chemically but it retains the glycerin. So what does that make it?
I started hauling cars and run about an extra 1000 miles or so a WEEK, and am looking for a cheaper fuel source. My usual B100 guy had a bad batch last week and he is kinda far to get to. Basically I want to run as cheap as possible, without losing any reliability, when I can't run B100 and trying to stay off #2. I'm looking at going dual-fuel, but donw the road a bit.Thanks for the help!
It's what would be called a blend. It's possibly thinned out with kerosene, gasoline, diesel, acetone, MEK, mineral spirits, or other solvents in combination, or just one or two of the above. So this 'fuel' is used by what are termed as 'blenders'.
That makes it a slow death for your truck. Run, don't walk, away from this bozo..................
Hey guys, I just got an email back from the guy, after I asked him what the process was, and this is his answer
"Hi Danny,
No problem with questions. The glycerine in base vegetable oil is what is most
potent. If you can recall nitroglycerin is dynamite. The problem is if the
glycerine is left untreated it does not combust completely or like diesel fuel
does. I settle, heat, centrifuge then react the glyceine with....... causing a
chemical reaction in which the glycerine binds with ...... molecules.
Sorry can't share the chemicals used.
The thought of biodiesel(which I have made before) is to just remove the
glycerine altogether, however removing it reduces it to a waste product when it
is what the fuel needs to be potent."
He sent a pic, and it looks nice and clear like new oil, but I am a bit disheartened that he won't tell me what chemical he uses. ANyone have an idea of what it could be>
"Hi Danny,
I have been experimenting with blending gasoline with waste vegetable oil (WVO) to make diesel fuel for 5 years. I know it works quite well, but it has its problems, just as the biodiesel process and the two-tank SVO systems have their problems. People, who experiment with fabricating diesel fuel out of waste products need to work out those problems. I am still working out the problems in my waste oil blending process.
Blending does not require chemical reactions. It just requires finding a useful solvent that blends readily with vegetable oil, blending it at a correct ratio, settling that blend to allow most of the contaminants to settle out of solution, knowing how long to settle, then filtering.
I have found blending gasoline at 20% with Waste Vegetable Oil (WVO) works quite well for my 6.2L diesel engine. I have found the fuel remains liquid down below 0F (-18c) and my engine starts right up at those temperatures on that blend without the need of a block heater.
I am still working out the settling time. I found settling for only 3 hours removes about 90% of the sediments including water. However, I have recently found that after filtering down to 1-micron there is still a fair amount of sub-micron sediment. So, I am increasing the settling time to 12 hours to see if that significantly reduces the sub-micron particulate. I will keep increasing the settling time until I find the sub-micron particulate is at a reasonably acceptable level.
It would be useful to know how much sub-micron particulate a 6.2L diesel engine can handle. I will find out by repeated trials.
Big problem!! Any diesel motor will run off of even straight WVO. the problem comes with the llife span of the engine. If you don't take the glycerin out (make bio diesel) or prepare it for a clean burn (heated WVO) then your going to shorten the life of the engine. The glycerin will eventually gum inside the cylinders, sticking rings and coking the injector tips. It is not worth it.
I can understand doing it with and old mercedes and running it until it just dies. Then get another one. But for my needs that isn't the case.
There are people all over the world successfully running vegetable oil in a diesel engine. There are three ways to do it. Most people react a base with vegetable oil through the medium of an alcohol. Other people burn straight vegetable oil, most typically in a two-tank system. And, third way many people successfully burn vegetable oil in a diesel engine is blending it with one or more solvents.
Most commonly people blend vegetable oil (VO) at 50% with diesel fuel. Some people blend VO with kerosene at a ratio of 70/30. Others blend gasoline with VO at 20% gasoline.
Most people on this forum are making a quality biodiesel or are using a HEATED two tank WVO system. Both have been shown to not cause any long term damage.
It is OK if some of us disagree as that is the American way. I run Bio D and I am in the process of setting up a 2 tank for my bus with a 6V92 Detroit. If all goes well I will have the last of the work done on the Detroit tonight. The first valves I tried on it dod not allow enough oil flow to feed that beast. I bought some SV200 valves from GReasecar and I will have them hooked up by 6 PM tonight. We shall see!!
I am OK with dissagreement, in fact as a blender, who has been active on most of the biofuels forums for 5 years, I am used to receiving a lot of disagreement. My point is, there are three well-tested ways to burn recycled vegetable oil on a diesel engine. Not, just two ways of doing it. Just because those who have not figured out how to blend successfully are against it, does not make blending an invalid method of burning vegetable oil.
If it's working for you then I would have to agree with you. Keep on with the keeping on as we wvo/bd/blender people are all in the same boat. We are all scrutinized, laughed at, called fools and don't forget we are crazy. So if we were to put down each itdrs methods or infighting so to speak, then we would not progress.
