Project Hank is a go! 4/15/2011 - Page 4 - Ford Truck Enthusiasts Forums
  #46
Old 06-14-2016, 10:19 PM
tubolove
tubolove is offline
tubolove is starting off with a positive reputation.
Note the axle is relocated 13" rearward. It now has the wheelbase of an extended cab truck.
  #47
Old 06-14-2016, 10:44 PM
tubolove
tubolove is offline
Originally Posted by 72CC428 View Post
What exactly are you running on those rims? Lo- profile rubber bands? I don't get it unless you are throwing on some f600 style fenders?
Running 265/40/22 tires. Yes they are rubber bands! They are load rated at 2180 each. Should be a nice margin of error in the front and rear.
The wheels have full range of motion. I will have to roll the front fender lip. Maybe have the body shop open the wheel openings a smidge but I'm not putting the horse before the cart there as I'd rather run 35 series tires before cutting the fenders.
  #48
Old 06-14-2016, 11:00 PM
tubolove
tubolove is offline
Here's a few shots of the rear four link
  #49
Old 06-14-2016, 11:02 PM
tubolove
tubolove is offline
Finish welded and back on tr ground.
  #50
Old 06-14-2016, 11:06 PM
tubolove
tubolove is offline
With the new tubular crossmembers in it was time to heave ho the old 70's work horse home built step bumper! Looks so clean now!
  #51
Old 06-15-2016, 02:44 PM
Brian1971f100's Avatar
Brian1971f100
Brian1971f100 is offline
Brian1971f100 has a very good reputation on FTE.Brian1971f100 has a very good reputation on FTE.Brian1971f100 has a very good reputation on FTE.Brian1971f100 has a very good reputation on FTE.
You got a lot going on there. Keep the pics coming.
  #52
Old 06-15-2016, 08:50 PM
72CC428
72CC428 is offline
72CC428 is starting off with a positive reputation.
Had me confused at first
This is wild. I can't wait to see it when it's done. Nice job.
  #53
Old 06-15-2016, 09:03 PM
tubolove
tubolove is offline
Will do!
  #54
Old 06-15-2016, 09:38 PM
tubolove
tubolove is offline
Thank you! Me too. I have a collection of images that inspire me. I'm not sure where this project will end but if you smash these images up and lay them on the Hank it will look something in the realm of :
  #55
Old 06-16-2016, 08:38 AM
Brian1971f100
So maybe I missed something here. What power plant are you using? Are you planning on boxing the frame as well?
  #56
Old 06-16-2016, 09:44 AM
tubolove
tubolove is offline
Power plant is a 12v p pump 6bt donated by my best friend. We will box the frame up front and above the frame notch over the rear axle. That's why I haven't built the pan hard bar yet. Planning the notch,box, and panhard bar right now since they all interconnect.
  #57
Old 06-17-2016, 03:58 AM
GaryKip's Avatar
GaryKip
GaryKip is offline
GaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to beholdGaryKip is a splendid one to behold
That 4-link looks good!
  #58
Old 07-21-2016, 09:48 AM
tubolove
tubolove is offline
Thanks Gary!
  #59
Old 07-21-2016, 10:01 AM
tubolove
tubolove is offline
Took me a while to figure out a pan hard bar location. There's not enough axle tube between the frame rails and the center chunk to weld a bracket too. With the air bags mounted behind the axle there's nowhere to add a pan hard bar behind the axle. I decided to build a bracket that bolts to the back of the rear diff cover. The pan hard bar will travel between the rear diff and the airbags.
Pan hard bar bracket
  #60
Old 07-21-2016, 10:04 AM
tubolove
tubolove is offline
Frame Notches fabbed up and frame cut to fit. Gives me 4" up travel at ride height.
Quick Reply: Project Hank is a go! 4/15/2011
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
