Why is my truck starting hard??!!! 03-7.3litre
How long did the light stay dim? How long does the wait to start light stay on? Questions I should have asked earlier. It is possible that some of the glow plugs aren't burning. See what the fuel injector cleaner does, that's for sure. If there is a place that sells bio-diesel, that is the best cleaner out there. You better have an extra fuel filter though.
Thanks!
I'm using the Rotella 15-40
Starting prob and not cold related. W/ vid - Ford Truck Enthusiasts Forums
I doubt this link works right but do a search for"Hard start and not cold related. With vid."
OK. So I went out this morning. Weather is overcast and a balmy 32°f. Truck has been plugged in overnight. Turned the key and 6 seconds later the glow plug light went out and BOOM! Truck fired up fast. Oil Pressure instantly went to where it should on the gauge.
So it seems that the issues are when the truck/engine block are cold.
#28
#29
With the heater plugged in overnight I would expect about a 5 to 6 second burn on the glow plugs. If it weren't plugged in overnight I wonder how long they would have burned. Typically with my trucks, they burn a good 30 seconds if they are not plugged in before the WTS light goes out. If it's really cold, I wait another 10 to 20 seconds before I try to start them. The GP's will burn for a minute or so even after the WTS light goes out when the truck is cold.
#30
I don't think I have ever had to wait 30 seconds for the WTS light to go out, even when I'm on the mountain. That is the only time that the truck isn't plugged in. When it's home, it's always kept in a heated garage (50°f) and at work it's plugged in.
This is why I am confused. It's actually acting like when the GP relay was going bad years ago, but since the relay is new and we just tested it with a test light I am at a loss for ideas.
