Dana 50 parts breakdown
on
Something like this:
Item Part Number Description
1 — Bearing cap (part of 3010)
2 4222 Differential bearing cup
3 4211 Differential pinion shaft
4 4228 Differential side gear thrust washer
5 4236 Differential side gear
6 4215 Differential pinion gear
7 4230 Differential pinion thrust washer
8 3010 Differential housing
9 4662 Collapsible spacer
10 4616 Differential drive pinion bearing cup
11 4670 Front axle pinion shaft oil baffle
12 372632-S Washer
13 354845-38 Nut
14 4851 Pinion flange
15 4859 Drive pinion oil seal deflector
16 4676 Front axle drive pinion seal
17 4621 Differential pinion bearing
18 3254 Axle shaft oil seal
19 4628 Front axle pinion bearing cup
20 4630 Differential pinion bearing
21 4109 Drive pinion position shim
22 3222 Differential ring gear and pinion
23 4241 Differential pinion shaft lock pin
24 4033 Differential housing cover
25 853051-S Fill plug
26 3C323 Bolt
27 4067 Differential bearing shim
28 355765-S Bolt
29 1244 Differential bearing
30 350672-S Bolt
31 4204 Differential case
12 372632-S Washer
13 354845-38 Nut
26 3C323 Bolt
28 355765-S Bolt
30 350672-S Bolt
I'm trying to think positive:
1. it's 9 degrees outside so I've got my freezer for the diff.
2. I have no idea why the diff needs to go in the freezer:
3. How much $ in specialty tools do you think this will cost?
4. What do you think the difficulty rating is on this on a scale of 1-10.
Can you tell I've never done this before....
For some strange reason I think I'm gonna give it a try.........
When mine went out, I replaced it with a used Dana 60. The guy I bought my truck from was running 40 inch tires and it blew the side gear spider gears to pieces.
If you could find a used Dana 60 one matching gears, it might be worth considering. It would depend on how much you have to pay for a used axle. A used Dana 60 cost me $1000 in Alaska. But I suspect you could come into one cheaper where there are more vehicles and more salvage yards.
I've been in and out of differentials a few times. There are a few specialty tools, and some knowledge, required. It's like most things. Easy once you know how to do it. For the first go round, you'll need to study up and research.
You're good to go with the freezer! The freezer helps to actually keep the diff assembly compressed so it goes back into the housing easier. It's a VERY tight fit.
What exactly is wrong with yours and what are you trying to repair?
The specialty tool to mount the inner seals was around $60ish I think. I can mail you mine for use if you need it and then just mail it back.
Difficulty isn't too bad unless you have to replace the diff assembly, then you have to get the spacing right and adjust the backlash. I've never done that part.
I'm not sure what is broken or happening yet. Due to lack of motivation and Thanksgiving being right around the corner I haven't had a chance to dig too deep.
Earlier last week I noticed that my 4x4 wasn't engaging. So I checked to make sure I heard the click on the transfer case when engaging into 4x4 and 4x4Low from the cab. Good to go on the click and the 4x4 lights coming on on the dash.
I put the Ex on jacks and lifted her off the ground. Manual Warn hubs unlocked, 2WD, shift lever placed in Drive. Both rear wheels spin as expected.
Next, I locked the manual Warn Hubs, placed it in 4x4, shifted it into Drive. No movement on the front wheels. The drive shaft from the transfer case to the front differential is spinning, but no movement of the axles or anything after the front diff.
The next step guess is pop the diff cover and take a peek - I guess
sorry to take so long to reply, Thanksgiving and the cold weather made for a busy week.
Anyhow, my problem turned out to be one of the Warn Premium hubs, everything looked good in the front diff, the passenger side hub would sometimes lock and sometimes not. I didn't realize that if one side doesn't lock you loose both. Hubs got sent out to Warn for warranty replacement.
rancherman84
01-06-2004 09:27 PM
