Edelbrock intake manifold temperature
Just wondering what kind of temperature the intake manifold should be on a 1978 400 Ford engine. I have the 4bbl Performer intake and Edelbrock Thunder Series AVS 650cfm carb. The thermostat is a 195 degree stat and keeps the engine on the lower end of the NORMAL range on the temp gauge. When the engine up to operating temp, I've taken some readings with a lazer thermometer. The intake manifold is 200-230 degrees while most of the other engine components (aluminum valve covers = 140 deg, thermostat housing ~180-195 deg, base of carb ~160 deg, etc.). Is the manifold getting too hot for this application? It's so hot that the split wire loom that I have covering the wires that go to the distributor starts to melt against the valve cover and intake manifold on the passenger side of the engine.
Can anyone verify if you are getting the same temp readings I am?
Thanks!
Thanks!
There is a crossover passage under the manifold that allows a small amount of exhaust gas to cross under the intake manifold between the heads. This keeps the manifold (and to some extent the carb) hot and allows better vaporization of fuel. It also prevents icing in colder areas of the country in the winter. Most "racing" manifolds eliminate this crossover in an attempt to keep the air charge as cold as possible to make the most power, but street driven vehicles need this heat.
So don't worry, its normal
On an Edelbrock performer manifold, does the engine coolant circulate through the intake manifold?
Since we're talking about heat related questions here, I had a stainless steel exhaust installed (headpipe off the headers all the way back to the tips is all stainless). My concern is the exhaust temp is turning the front head pipe a brownish / bluish tint almost like the exhaust temp is too hot. The pipe is changing this color back to the first muffler. Is this normal? I've checked the spark plugs and they are a tannish color so I'm thinking the air/fuel mix ratio is OK? How would a guy check if I have the correct jetting in the carb?
Braindamage, talked to a coworker today and he also confirmed that stainless will change colors when heated. I did check plugs and they are tannish color, not white or black, so the carb should be somewhat OK according to Edelbrock tech guy. Guess I'll have to learn how to use a vacuum guage to set the carb.
SixPoppin'
09-21-2016 11:03 PM
1986F150six
15
09-06-2015 08:13 PM
oldmansimek
01-18-2006 11:11 AM
