Ryan's 72' F-250 project
The engine compartment received a much needed intake manifold gasket set, new Holley 080457-S carburetor, air cleaner, hedman headers, 3" exhaust & super 44 flowmasters.
I have ordered new headlights (H4 conversion), taillights, side markers, & clear turn signals.
I have removed the 3 inch body lift, the 39.5 swampers fit snuggly with some minor fender trimming.
Good looking truck I have a 71 f250 4x4 what kind of suspension is on your truck? Is it stock springs or is there a lift kit on it? And what are the tire measurements and what kind of super swampers are they? Looking forward to seeing more pics of your progress what's your plans for the truck?
From what I can tell its a 4 inch lift kit, front springs and rear blocks. The tires are some worn 39.5X15X15 TSL's.
Plans are paint, interior work, 73-79 dana 44 or 60 swap (closed knuckle 44 with drums currently) and steering swap and fabrication as well (has the f250 hydraulic assist currently). I'd like to get the AC working again. Other than that just a pickup and tow rig, its a blast to drive.
is the axle currently a 8 lug? if so how well do the 15'' rims fit? i always thought that you couldn't fit 15's on the 8 lug DANA 44 do the tires rub anywhere? if your swapping front axles i'd suggest finding the 44 or 60 out of a mid 77-79 f250-f350 they have open knuckles disc brakes and are pretty much bolt in. also the power steering setup that's what i'm doing to my f250 right now
It is 8 lug, they fit fine..it does have 1/4 washer spacers. An open knuckle 44 or 60 is the way to go with disc brakes. No matter the steering its going to need some fabrication due to the F-250 hydraulic assist. Its a manual steering box push/pull front to back with 2 hydraulic cylinders and 6 hydraulic lines. Its way too much to worry about, rather swap it out for a power steering box with 2 lines, fabrication of the frame will require plating and re-drilling to the proper dimensions.
Installed new taillights and went crazy with some serparte glass blue dots, if I were to do them again I'd go with ones already installed. There is some satisfaction doing your customization...however it doesn't outweigh the hassle of this installation. Instructions say "use 15/16" drill bit and install dot". Sure! find that at your local hardware/home improvement store. You'll end up using a 3/4" bit and carefully cutting the rest with a pneumatic bur bit.
I'll be doing the 78-79 f250 power steering conversion this summer sometime I agree to ditch the power assist for real power steering theres some good writeups online and acouple different methods people used I got to get my lift kit on and engine trans in before I start the steering I already have a Dana 44 front from a 79 along with complete steering for the swap ill be looking forward to some new pics of your progress I am a big fan of 4x4 f250's
RacinNdrummin
2196
10-20-2018 05:56 PM
mattjensen
37
12-11-2013 05:02 PM
projectdagger
04-11-2010 10:53 PM
