5.0 HO Engine in to 91 f-150
I got the motor in and running yesterday. Runs great except for an irratic idle. It is surging about 100 rpm. I am thinking all of the oil the other motor was blowing may have clogged the iac up a little bit, and possibly the air filter. I am getting codes 18,41. I also think it may have clogged the O2 sensor. I also need to re-check all my grounds again because of the spout code (I have had that problem before and tracked it down to a bad ground). Other than that it runs really good. Thanks again for all the help.
brcrk
16
01-09-2007 03:03 PM
cwmerc88
08-16-2002 11:39 AM
