Help needed on solving constant problems with my 6.0
Old Apr 13, 2011 | 09:45 PM
bismic's Avatar
bismic
Originally Posted by cheezit
a little interisting info. failed egr cooler are knowen to kill injectors, along with running low on fuel, low fuel pressure.. ect ect.
Could you explain some more regarding injectors being killed by a failed EGR cooler?
Old Apr 13, 2011 | 09:50 PM
cheezit's Avatar
cheezit
sure mark.... your just overthinking....
what happens is the coolant will enter the main oil supply for the engine via one of 3 ways.
1) drain past the rings after sitting
2) recondense from the steam form in the oil pan.
3) stick to the wall of the cyclinder and get wiped down by the oil ring.
when this happens we will have a high level of gylcol and whater mixed in with the oil. the mix is then picked back up by the lp pump and sent to the high side system were its pump threw the injectors and they dont tend to like that much.
Old Apr 13, 2011 | 09:58 PM
bismic's Avatar
bismic
Thank you cheezit!
Do you know what concentration of glycol in the oil begins to be damaging (for those of us doing regular oil analysis)? I assume it is low ......
Old Apr 13, 2011 | 10:00 PM
cheezit's Avatar
cheezit
Originally Posted by bismic
Thank you cheezit!
sorry I dont. I can tell you the one I suspect as the cause have injector failers shortly after egr cooler fails with oil and water/coolant in the pan
Old Apr 13, 2011 | 10:07 PM
motor-man's Avatar
motor-man
So cheezit what your saying is basically you change the oil right away after an EGR cooler failure?? Or is it too late to matter...
Old Apr 13, 2011 | 10:08 PM
cheezit's Avatar
cheezit
always change the oil after doing a cooler reguardless.
no way to know how late it is. soem times things go good sometimes not so good.
Old Apr 13, 2011 | 10:10 PM
m-chan68's Avatar
m-chan68
ANY EGR/oil cooler replacement mandates changing the oil and filter and refilling with new coolant (at least for me it does anyway).
Old Apr 13, 2011 | 10:13 PM
bismic's Avatar
bismic
Good things to know - thanks guys!
Old Apr 13, 2011 | 10:18 PM
BGL36's Avatar
BGL36
just throwing this out there about your truck having low power. have you checked exhaust back pressure sensor/ and tube to sensor. We run 11 econolines with 6.0L and along with my personal truck and they all act low on power and shift really rough when the sensor and/or sensor tube is plugged. im not 100% sure (somewhere around 14psi i think) on the spec but it should drop psi fast when u let off the throttle and not have much back pressure because you dont have a muffler.
Old Apr 14, 2011 | 07:16 PM
guthrie&co's Avatar
guthrie&co
gutnther you will never get rid of the lag. its boost lag. just not gonna happen.
The best you may really hope for is by possible going to a custom ficm tune. The few I have drive seemed to have less lag.
what color smoke. black,blue or white? if its black then its unburnt fuel. to some extent that maybe normal too.
It's black smoke so it is unburnt fuel. Surely it can't be normal to have this much turbo lag and smoke like this....
Old Apr 14, 2011 | 07:21 PM
cheezit's Avatar
cheezit
do you still have a cat?
black smoke on excel or when cold is not that uncommon. post a video
Old Apr 14, 2011 | 09:14 PM
FishOnOne's Avatar
FishOnOne
Was your EGR valve replaced or was it cleaned. Your symptom sounds like my truck when the EGR valve wasn't operating properly before it eventually failed. Lacked low end power, very sluggish on take off, and blew out black smoke was related to my EGR valve.
After a year with the new EGR valve, my truck experienced the same problem again recently, but I know it just a matter of time and I'll need to replace it again. This is with the latest flash and the new designed EGR valve.
Good luck....
Old Apr 16, 2011 | 01:15 PM
  #28
guthrie&co's Avatar
guthrie&co
I still have the cat. Black smoke when I accelerate.
Good luck....
The egr was replaced. 3 times
diesel_s
Dec 8, 2014 09:44 PM
ol-blu
Mar 3, 2013 07:06 PM
Hawk180
Jun 24, 2011 08:22 AM
f250rollinon37s
Dec 24, 2010 04:12 PM
ggirten
16
Sep 15, 2008 11:53 AM
