im talking about the high pressure line fittings in the pump
I suppose that your new pump has the stock fittings and not the SD pumps (quick connect), rigth? if so, When I changed the o-rings I didnt heat them, I only used two 11/16" open wrenches to do it, its a PITA because is tight there but doable. good luck.
one of the o rings on the hpop line had split in 2 and was causing long cranks and an oil leak i chased for a week
went to ford this morning and bought new o rings and replaced them
and i have a modded 17* pump but i used my factory obs fittings.
Ok, thank you. So you dont heated them and you dont use loctite, right? and just curious what was the o ring that had split in two? the one to the front or the rear one? In mine the frontest was the bad one.
