OBD 1 ?
Old 09-24-2017, 08:22 PM
bigcrunch's Avatar
bigcrunch
bigcrunch is offline
OBD 1 ?
I have a 1997 F250 460 auto build 01/97 it has a OBD1 connector under the hood. No OBD 2 for the last of the 460's ?
Old 09-24-2017, 08:29 PM
andym's Avatar
andym
andym is offline
It wasn't mandatory on trucks with a GVWR of 8500+ in 1997. The PSDs were all OBD-II but they technically didn't need to be at the time.
Old 09-24-2017, 11:20 PM
jtmalott's Avatar
jtmalott
jtmalott is offline
Is this truck an HD? I'd so it's probably EEC-IV
Had the same thing with my 96 F-superduty. Assumed that post-95 was all OBDII but I was wrong. Getting diagnostics blows, but the code readers are most likely on clearance at your auto part store for 25 bucks
Old 09-25-2017, 05:04 AM
bigcrunch's Avatar
bigcrunch
8600 GVWR
Old 09-25-2017, 08:10 AM
mrollings53's Avatar
mrollings53
mrollings53 is offline
They existed, but were only sold in California.
Old 09-26-2017, 04:48 AM
bigcrunch's Avatar
bigcrunch
If I come across a California it has a sticker under the hood and on valve cover?
Old 09-26-2017, 08:13 AM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,151 Likes on 910 Posts
The VECI label will state what type of powertrain control it is equipped with.
The other dead give away is the air filter box will have a MAF sensor.
Old 09-26-2017, 08:16 AM
1989FordF250's Avatar
1989FordF250
1989FordF250 is offline
Hey were are you guys getting your OBD 1 code readers at? I would really like to have one of these instead of reading the flash codes on the CEL.
Old 09-26-2017, 08:26 AM
mrollings53
Old 09-26-2017, 09:31 AM
rla2005's Avatar
rla2005
rla2005 is offline
That Innova code reader is one of the best. I have seen them carried at the local parts stores from time to time. Highly recommended it.
Old 09-26-2017, 09:38 AM
1989FordF250
Okay this is great I will definitely be ordering one of those tonight! You just cant really get an accurate answer counting flash codes so this will be great!!
Nothing Special
04-12-2013 07:10 AM
MONAVIERONJON
04-17-2011 12:48 PM
BodegaErik
07-02-2006 02:41 AM
bobdog
01-16-2004 05:23 PM
82F100SWB
05-09-2003 12:16 PM
Quick Reply: OBD 1 ?
