Flathead Engine Help.
Old Apr 11, 2011 | 05:49 AM
xcrunner2616's Avatar
xcrunner2616
Well i got the oil pan off my 239 yesterday afternoon. put the truck into neutral and spun it all the way over. it sticks pretty bad on the 2 pistons that was all the way down when they get to the top. the oil that came out of the pan had adviously never been driven. it looked like it was brand new. the crank, bearings and connecting rods all look good. but being as though the 2 cylinder walls are a little rusted they are probably pitted so i will need some boring. i guess i will complete my tear down. which leads me to my next few questions.
1) am i going about this the right way?
2) will my regular engine stand work?
Old Apr 11, 2011 | 07:05 AM
petey shoes's Avatar
petey shoes
don't know enough about this, but sounds like all bearings, rings, etc. don't forget cam. engine stand should be ok.
Old Apr 11, 2011 | 08:18 AM
mtflat's Avatar
mtflat
quote: "it sticks pretty bad on the 2 pistons that was all the way down when they get to the top"
say what?? lol
Likely 2 cyls had valves that were open as it sat. Honing at least, would be a good idea.
1: yes - there isn't a wrong way to open one up.
2: Which flathead 239? Late series (48-53) will be ok on a regular engine stand, but don't use a cheap HF stand with one leg up front - use a heavy duty stand since flatheads weigh over 500#s. Those 3 point stands tip too easily.
Old Apr 11, 2011 | 09:34 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Have you determined that the pistons are what is sticking at the top of their travel, or the valves? Have you got any pictures showing the cylinder condition?
Old Apr 11, 2011 | 09:42 AM
xcrunner2616
i will take lots of pics and post tomorrow. the 2 are sticking at the top of the stroke. i can push past it but they are sticking at the top. i will tear all the way down and sent off to pressure test/hone/bore or whatever it needs. i will then replace all bearings/pistons/rings/ valves/valve springs. i dont think i will replace the crank or pushrods. they look great.
Old Apr 11, 2011 | 11:00 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Pushrod wear is usually pretty minimal in flatheads
Old Apr 11, 2011 | 12:23 PM
Doc's Avatar
Doc
Hey xcrunner, we've asked this before. But why don't you post your location in your control panel? Maybe there's somebody nearby who can help out.
Old Apr 11, 2011 | 02:08 PM
52 5 star's Avatar
52 5 star
When I rebuilt my flathead I made a 3/8 plate that bolted to the exhust side of the block and cut a thick wall steel pipe that fit the engine stand and welded it to the plate. can't remember the angle to cut the pipe on the plate side. But this works a lot better tan connecting to the back of the block. A lot more even on weight when turning the block over to disassemble and assemble there is pic in my profile of the engine on the stand.
Old Apr 11, 2011 | 02:33 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Not mine, and this is "extra fancy" with the chain-drive to rotate, but you can see the type of plate 5 Star is talking about. They are sold on eBay, and as heavy as these blocks are, unless you are a good welder, I'd just buy one. Also note the 4-wheeled stand as MT suggested.
Old Apr 11, 2011 | 02:39 PM
52 5 star's Avatar
52 5 star
Like your drive on the stand. I used a flywheel and a starter gear
Old Apr 11, 2011 | 03:47 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Not mine; he used a Chev timing gear set!
Old Apr 11, 2011 | 07:01 PM
55 f350's Avatar
55 f350
let us not forget ross that ford themselves once upon a time called the lifters " pushrods " in their own manuals ............. so technically he's right in calling them that if that's what he's refering too .......
Old Apr 11, 2011 | 09:14 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Point taken, just funnin' here...
So are the lifters/pushrods stuck, or the valves, or is it the pistons? Seems premature to go whole hog just yet.
Old Apr 12, 2011 | 07:12 AM
petey shoes
good point on 4 leg stand. i quess i just forgot about those 3 leggers.
Old Apr 12, 2011 | 09:02 AM
55 f350's Avatar
55 f350
true on going whole hog . when i first got my 53 it had one bent valve and a bad guide . replaced them and drove it as much as i could till the 1 valve spring collapsed and the wiring went up in smoke literally . all i'm replacing in the flatty before it gets dropped into a straight frame and the rust repaired in the body and dropped on it as is ... is the cam is getting swapped for the merc 8cm , new oe lifters , new elgin springs and stainless valves ( which would not have been replaced had the old ones been ground just a few times , not leaving enough for another go around for lash adjustment ) and locks , and timing gear . why mess with anything you don't have too ?????? oh and an intake and carb swap . all relatively easy things to do and the short block which is sound is untouched and saves me or in your case if it is , money for other things and one less thing to wonder where the hades you laid the parts too it ...............
