2004 F-250 Transmission Fluid Temp Sensor
2004 F-250 6.0 Turbo Diesel W/ Torque Shift Transmission. Im having a problem with my Check Gauge light coming on and Tow Haul light flashing on my 04 F-250. I got a Transmission Fluid Temperature Sensor from my local Ford Dealership. They also said i needed to replace the Transmission harness for this application because of an open circuit. My questions are, Is Mercon SP the only ATF that can be used on the Torque shift transmission (im sure it is, just wondering if anyone heard of or used an alternative), and do i really need to replace the harness or just the sensor? I have read up a little on this and so far everything say's drain the fluid, drop the trans pan, swap out the sensor, replace the trans pan (torque setting is 11flbs i believe, correct me if im wrong, replace with Mercon SP ATF and your good to go. If anyone has replaced this sensor and ran into any problems or know's any little tricks to it, that would be very appreciated. Thanks
The filter is housed in a aluminum canister just behind the passenger side bumper. When you start to remove the filter housing don't apply a slow torque, but rather a fast motion. The ideal way to remove it is with a impact gun. Don't worry about the internal filter that you will see when removing the trans pan. This filter gets replaced on a rebuild. Lastly you will need no pan seal because the one from the factory is a permanent one.
harness
"the advise to replace the harness was in fact valid. we have some issue with that as well. IMO I would replace the sensor first and go from there however "
Part number for the harness?? I called the dealer and they want $29 for the sensor and $260 for the harness. Going into a 04 F350 Harley Edition.
Thanks!
Thanks!
Oilfan94
07-16-2018 08:51 AM
