Festus needs help in Ohio
Have him call Kevin Cragan at TI Dyno.
Kevin is in Ashtabula (only a few miles from Geneva) and does a lot of Diesel work.
Kevin's number is 440-474-2059.
Tell him Jim Rose referred you.
Hope he can fix him up.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
There's a guy on OBN willing to help
Here's the link: IDI owner needs help in Ohio. - Oilburners.net
He just needs a number to call Festus.
Wow, I totally spaced out and missed the Geneva, OH part. Big detail.
Is he planning on running 90 East out to 95 North?
If not, what is his planned route?
Is he towing a trailer, have the truck packed with spare parts?
I can meet him somewhere on 90 in New York and try to haul some stuff back home if that helps at all?
I've got an 11' long x 6.5' wide flatbed I can pack with parts.
My trailer hitch might be a bit too tall...it's 25" from the ground to the top of the ball. I have a 2" ball hitch and a 2-5/16" ball hitch, and both are a pintle combination.
When he gets back up and running, let us know! I'll be on stand-by when he's running thru my area. I could go about 4 or 5 hours West or East of Springfield, MA on 90. Basically, between Syracuse, NY and anywhere back home to Maine I can help out with.
PM (private message), click on the members name. Then on the scroll down menu, select "Send a private message to _____ (users names)". That's the easiest way to send a PM.
The best way to check your PM's, at the top right corner of the page there's a box that says "Welcome Festus Hagen".
Underneath that, 2 lines down, you click the blue link that says "Private Messages".
That will take you to like an email account type setup. You can check your inbox to read your PM's.
If you have received a PM, then it will say "Unread: 1 Total: 10". Those aren't the same numbers you may have, but it's just an example.
