Battery and alternator wire upgrade
I think your seeing the coolant filter. Thought about it but seen on youtube where a person did a full install and didn't make much of a change (according to him) in temp, but easier to change the oil filter. No luck on the lugs, kinda buried.
Good to see you checking back in Dave
Hey My Reman Alt Died LOL it died 13months and just under 5K
Your right the stereo KILLED IT
At that point I was tapped out for Alternator Money Kinda I had called DC Power told them what I had for stereo and they said that 185amp would do Fine
MY GOD Think back on it in that 13 months I spent Almost $900.00 Bucks on Alternators I should have the Best one Made LOL!!!! But I Should Hate it when crap happens
SO I got a 190amp it had better Idle amps advalible
They Gave me a Wire upgrade cable from DC But I was thinking the other day I really should do the Grounds To
Did that Inductive amp meter come from Custom battery cables.com its on my List for a Standalone Gauge
I am Curious to he should have some pretty good miles on it Now
Just looked I only have 25,000 Miles on my DC 190 BUT my Stereo does work it if I crank it up
But that's 20,000 MORE Then Reman FORD LMAO!!!!!!
Glad you found it helpful. My 250XP has been great! No more power problems. When my Optimas cycle time was up went with the odysseys (pricey but seems to be a good match).
Upgrading the grounds along with the positive wire is almost (if not more) as important. This tool for the frame ground made it easy to clean it up.
Pilot Bonding Brushes
AutoMeter Cobalt Gauges
For the ammeter it's for measuring audio amp wires. Not very under the hood friendly and expensive. Works good most of the time, but when the heat gets to it (mostly in the summer), it gets finicky. The red button is to select speed response on the ammeter. Always keep it on slow, does less jumping around.
Note: Fuel Pressure was before the blue spring upgrade.
Great to hear its been problem free. My only concern is I had mine painted and it took about 3 months to get, so I kept my OEM just in case I need to send the DC back if it fails during warranty period.
Didn't have mine painted, but have my old one as a backup (didn't fry it before the change. Emergency use only!!!) LOL
#28
since we're on this topic, i do have some questions. the positive connector which connects to the passenger side battery seems like it was scorched a little. it looks a little copper-ish. should i be worried about it? if so, maybe i should just change the connector?
also, i'm not too sure about my grounds. maybe someone could tell me where to look and what to look out for. thanks.
lastly, my passenger side battery is leaking off the top side. i'm starting just fine. it starts quick and should i be worried about my battery? i just cleaned it up real good. she still starts fine. it was replaced last year in february. should i get it replaced again?
thanks guys!
thanks guys!
#29
thanks guys!
thanks guys!
Does it look like this?
If so, I think the battery acid got to it and ate the coating on it. if it starts crushing like the picture start thinking about replacing it IMOP.
As for the battery leaking already it should be under warranty and would exchange it. I would replace it.
The main grounds for the batteries are: Passenger side, on the underside front of the engine by the balancer. Driver side, under the air cleaner and might need to move aside the CAC tube, on top side of the frame. if you see corrision on the grounds than clean them. if your starting fine, I wouldn't worry about it.
Dave
#30
Does it look like this? If so, I think the battery acid got to it and ate the coating on it. if it starts crushing like the picture start thinking about replacing it IMOP. As for the battery leaking already it should be under warranty and would exchange it. I would replace it. The main grounds for the batteries are: Passenger side, on the underside front of the engine by the balancer. Driver side, under the air cleaner and might need to move aside the CAC tube, on top side of the frame. if you see corrision on the grounds than clean them. if your starting fine, I wouldn't worry about it. Dave
Yeah, only the positive terminal connector on the passenger side battery looks like tat. Everything else is fine. Any suggestions on a good replacement terminal connector? Someone had mentioned the noco battery terminal from O'Reilly's.
Thanks,
Dom
Sent from my iPhone using IB AutoGroup
