On board air compressor
Old 04-07-2011, 03:42 PM
IDI Diesel's Avatar
IDI Diesel
IDI Diesel is offline
Hey guys,
I know its been done before but I cant find how. I have a 7.3 diesel with air conditioning. I never run the A/C and it leaks so im not going to bother fixing it. Iv herad that people have turned the A/C motor into an air compressor to fill air tanks. I plan n doin this to run air horns and air bags. Any ideas how to convert the air compressor??
Thanks
Old 04-07-2011, 04:48 PM
bobbyjo9's Avatar
bobbyjo9
bobbyjo9 is offline
Havent done it but I would think it easy to plumb.. just run the charge line with a 1 way valve to a tank, replace the return line with a filter and use the AC clutch as the on/off switch. The part Im not sure about would be the lubrication since the R134 takes care of that in a closed system??
Old 04-07-2011, 05:05 PM
snaponprofile's Avatar
snaponprofile
snaponprofile is offline
I talked to guy who did it and he said his a/c pump eventually seized, I just bought a onboard air kit from horn blasters for air horns, tire inflations, use of nail guns etc.
Old 04-07-2011, 05:06 PM
cj06's Avatar
cj06
cj06 is offline
Old 04-07-2011, 07:49 PM
Volvo92906's Avatar
Volvo92906
Volvo92906 is offline
Yup I did it for a while. You need to manually oil the compressor because it was built to be oiled by the freon going through it and that is gone. I did it for a while and it worked well.. Mine eventually seized up due to age (happens even with working a/c systems) so I just switched to a stand alone compressor.
As for the semi compressor mod for a vehicle, thats pretty awesome but probably pretty expensive also. I have air shocks and horn on my truck... If I had more it might be a good thing to do the install.
Old 04-07-2011, 08:06 PM
IDI Diesel's Avatar
IDI Diesel
been searchingaround and found kit. ems like a fair price. anybodyuse one before?Shocker 22X
Old 04-07-2011, 08:12 PM
cj06's Avatar
cj06
cj06 is offline
for that price i would fab up a york compressor , they are not lubed by the freon as they are lubed just like a engine ( splash lubed )
schoo
17
03-15-2022 09:39 AM
1JDMarty
03-17-2020 06:43 PM
sittinguy
Aerostar
08-06-2017 05:45 AM
braduh60
08-06-2012 09:18 AM
DOUG5G
Aerostar
01-29-2006 06:47 AM
Quick Reply: On board air compressor
