custom intake on 1986 2.3L , HELP needed - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Small Chassis Trucks > Ranger & B-Series
Reload this Page >
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 04-06-2011, 06:05 PM
darkside_ranger's Avatar
darkside_ranger
darkside_ranger is offline
darkside_ranger is starting off with a positive reputation.
Exclamation custom intake on 1986 2.3L , HELP needed
im looking into increasing the intake flow for my 1986 2.3L ranger to match the exhaust and engine work ive re-done,
there is a idle air control valve mounted on the current airbox that runs a 2nd smaller airtube to the throttle body, is there a intake kit i can buy that will mount this IAC, or should i even bother?
THANKS ! , steve
Old 04-06-2011, 07:26 PM
KhanTyranitar's Avatar
KhanTyranitar
KhanTyranitar is offline
KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.KhanTyranitar has a very good reputation on FTE.
I would not even bother. The stock intake will outflow the stock head. The stock intake is already well designed, its hard to improve on. Unless you add a turbo, the stock intake is all you need.
Old 04-06-2011, 10:16 PM
Dutter's Avatar
Dutter
Dutter is offline
Dutter is starting off with a positive reputation.
Yeah but if you do enuff little things it adds up to a fair difference, But on a smaller motor i dont think itd make much of any difference, Like on bigger motors i know theres a difference in power, but the smaller motors come with intakes that are pretty close to the bigger motors, so there already running the bigger intakes, but if ur just wanting to tweak something then sherr go for it
Old 04-12-2011, 06:12 PM
GymClassHero
GymClassHero is offline
GymClassHero is starting off with a positive reputation.
i just gutted the intake off my 88 STX, K&N knockoff and a hose clamp over the throttle body, i wanna say it seems peppier but its probably all in my head
mtech1950
Ranger & B-Series
03-12-2013 11:36 AM
wtroger
Ranger & B-Series
11-13-2007 06:11 PM
ltabora
4 Cylinder Engines
08-23-2004 06:58 PM
heke
Ranger & B-Series
03-28-2003 05:48 PM
jbusic
Ranger & B-Series
03-21-2002 07:18 PM
Quick Reply: custom intake on 1986 2.3L , HELP needed
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
