Rearend trouble
get some rear fluid, and some friction modifier additive from Ford, drop the cover and have a look see, if nothing broken fill and add additive, and start lookin for some parts. The lim slip clutches would really only show up on turns, the comming to a stop and straight take off would concern me.
You could have two problems. Not enough friction modifier and driveshaft slip joint needs lubing.
See these links for more info.
Sterling 10.5 Gear Lube Change
Slip Joint Regreasing
Robin, do you have a link to rebuilding or replaceing the rear diff. My boy wants to change gear ratio's in his SD from 3:73 to 4:33 or 56. He's got 35 tires and tows very heavy toy hauler. Plus he's a 6.0. He's also 4x4 so we have to do both. I never did one before but it dosen't look hard. Thanks,
Chet
Chet
Chet
Chet
You can try other Super Duty sections. Gassers have the same diffs.
Chet
Chet
