Torque converter or tranny?
Old 04-05-2011, 07:47 PM
rubantin007's Avatar
rubantin007
rubantin007 is offline
My truck is slipping and shuddering when I start moving or when it shifts. Is there any way to tell if it is the converter or the tranny?
Russ
Old 04-06-2011, 11:24 AM
rla2005's Avatar
rla2005
rla2005 is online now
Received 1,153 Likes on 911 Posts
Year/model/engine/transmission type? Have you checked the fluid level?
Old 04-06-2011, 01:24 PM
rubantin007
1992 ford f-150 4.9L 2wd E4OD... Fluid is red up to level and doesn't smell yet
Old 04-06-2011, 02:26 PM
Kapusta's Avatar
Kapusta
Kapusta is offline
Received 1,715 Likes on 641 Posts
Sounds like worn friction discs in the clutch packs.
Old 04-06-2011, 05:14 PM
rla2005's Avatar
rla2005
The E4OD is 100% electronic controlled. Before tossing in the towel or blindly replacing parts, check for codes. It could be as simple as a faulty MLPS or a bad connection to the solenoid pack.
Old 04-06-2011, 05:51 PM
rubantin007
how do I check codes on an old vehicle like this?
Old 04-06-2011, 06:13 PM
rla2005's Avatar
rla2005
Warm up the engine and transmission then follow this: Ford Fuel Injection » How To Run a Self-Test
Or purchase one of these: Amazon.com: Equus 3145 Ford Digital Code Reader: Automotive
Your truck should display 3 digit error codes: Ford Fuel Injection » 3 Digit Self-test Codes 111-171
When running the tests the first set are called Key On-Engine Off (KOEO). If there are no faults a System Pass code of 111 will be displayed twice (111 pause 111). The next set of codes that may be displayed are called Continuous Memory. These codes are a historical log of anything that has triggered a code since the last clearing of the codes or removal of power such as removing a battery cable.
That is a good place to start. There is another set of tests referred to as Key On-Engine Running (KOER). This is a set of tests run on various sensors and also required input from the user.
Right now you need to see if there are any KOEO or CM codes.
