MISSING ON AN INJECTOR??????
I tried to post yestarday but DSL dropped.
What I would do is remove the valve covers, start the truck and unplug the injectors one at a time and see if you can find the one injector (or more? do them all) that does NOT make the engine stumble when you unplug it. This is the one NOT firing.
Then, you can swap the valve cover gasket and under cover harness one at a time to the other side, re-start and see if that intial cylinder still does not work or if the problem moved with the vc gasket OR under cover harness.
This will help narrow down if it is an injector or the gasket/wiring.
If you see it is the initial injector still not firing after swapping parts, I would swap that injector quickly with the one next to it to make sure it's not the IDM or other wiring issue. If the injector is the culprit it won't fire in the new hole either. If it's something else then that initial cylinder still won't fire.
Make sense?
Make sense?
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
YouTube - FORD DIESEL OBS
symptoms are when i try to start it when the engine is not warm thats what it sounds like (also if i shut it down when its not warm it sounds not good) if i start at op temp all is well. any ideas?
Yup....Wheelie's sounds a bit different than what I'm used to. Two things in particular. First, I don't hear near as much of a LumpLumpLumpLumpLump in his. Second when he lets off the throttle it goes back to a solid idle immediately with no stumbling around before it "finds" it's beat again.
Wheelie, I assume when you went from high speed to idle you did a quick drop off the go pedal????
DZL JIM, many many thanks for the good diagnostics!
#30
