Installing a 302 EFI in a 56 F100
Well my two cents, for what it is worth, this is the way I build my toys.... since you have a complete running donor you should have most of the parts you need.
If you are not doing all the work yourself and/or with with friends help it will be expensive. You need some wiring, welding and fabrication skills or available friends with these.
I have swapped many drive-trains from donors to cars/trucks they weren't factory installed in. It can be time consuming and you may have some hair-pulling out days trying to get things to work but strangely that is what I enjoy doing.
Remember Google and car forums are your friends, as believe it or not most swaps have been done before.
Good luck whichever way you go, very fulfilling when it is done and you did it yourself.
What part of Idaho are you from?
Craig
waynesel
29
11-14-2020 10:10 AM
rico56
13
05-08-2017 05:38 AM
waynesel
11-12-2016 09:57 AM
56 f100 long
03-16-2016 02:39 PM
