View Poll Results: Should I go with Redhead Steering or Lare's Corp for Power Assist components?
Voters: 10. You may not vote on this poll
Redhead Steering vs. Lare's Corp
Hi guys...I'm looking to have some of my Power assist components rebuilt or swapped as a core, all bendix style (power cylinders and control valves). Swapping in 78/9 stuff isn't going to happen on these rigs (but since I said that, God knows someone will suggest it to be a smart allec), so please don't suggest that. However, my question is which company is the better option to go with? Redhead Steering or Lare's Corp for the re-builds. Who does better work?
Currently, Redhead is more expensive, but they have the parts I need in stock. I ship them my parts, which bypasses the core charge, then they'll send me what I need. But like I said, they're about $75 more expensive.
Lare's, doesn't have any in stock, says it'll take 2 weeks to rebuild what I send him...if it's rebuildable, but he's cheaper.
Money really isn't the deciding factor (unless they're just that evenly matched), it's more quality and expected life of the rebuild. So any info or thoughts is greatly appreciated.
i personally never heard of lares corp so i can't say anything about them i did just check out there website and they seem to do just about any kind of pump and gears for any vehicle so they must have alot of business under there belt. redhead stearing is alot of what i hear on the forum when it comes to rebuilding with the machining they do so it's better then factory and fixes the leaking box's we seem to all get after awhile. ive heard nothing but good things about them i have called and priced my box to be rebuilt by them although they are alittle steep on there prices i was thinking of sending them my box when the time comes but im always looking for better or just as good places with as good of a rep as redhead has
I cant speak for Redhead, but I have Lares parts on mine. (76 F250) I purchased them in the early 90's and have no leaks so far. I purchased the rebuilt ram, control valve and gearbox. One thing they did, good or bad, is they used grease in the gearbox, not 90w gear oil. The steering is still factory tight, well, as tight as this power assist setup get's anyway. I also rebuilt my steering colum and replaced the steering shaft at the same time.
I dont have any experience with Redhead. I've heard they fix some factory flaw in the steering box. I'll probably use them when I replace mine. I used Lares for my cylinder and have had no problems. Seems like quality work. Aside from the box it seems like they are pretty even. Same quality with a little better prices will send my vote to Lares.
Seems I am the only one. lol
I've called and priced a rebuild with the machining to the lower bearing/ seal area that they fix because Ford didn't do it that way from factory so that's why they get that leak but for a 79 f250 4x4 power steering box it came to almost $500 with shipping and almost $600 if you don't have a core
NPD (which is supplied by Lare's) is 225 plus a 250 core charge (out of stock anyway)
Redhead is 356 plus a $300 core charge
Lare's is 236 plus a $150 core charge.
These are prices/quotes I received on Tuesday.
You can bypass the core charge by giving them a call and letting them know you're sending in your part.
it does sound abit steep to me to but the quote i got when i called 3 months ago was over 400 for a rebuild with a core shipped just like you say then i got a quote for no core so it came to under 600 shipped
In new form it's not so bad and will suit my needs, and I believe it catches a bad rap from guys that see old worn out parts leaking, and don't fully understand the system. Then they hop on line and believe perpetual misconceptions about the system. I've run upwards of 38's with this system with minimal issues. I've got a couple valves that I had done a few years back by a local guy that claimed he knew what he was doing, they came back leaking still. Took them to a hydraulic shop, they got good enough to live with, so now I figure I'll let someone who knows what they're doing try their hand at it. Besides, the system lasted darn near 30 years, even the 78/9 setup has to wear out at some point.
Some guys just blindly echo the mantra "power assist steering sucks" because they don't know any better and it's all they've ever heard.
A power steering box has a hydraulic piston inside with pressure porting controlled by a torsion valve, all in one nice and neat, clean little package, it puts all of its steering force through the pitman arm, pushing one of the steering knuckles off the frame, power steering boxes have built in force limitations.
Power assist systems on our trucks use a push-pull valve with a hydraulic ram, in decent shape this factory setup goes down the road just fine, the power assist is an excellent built in steering damper and puts 100% of its turning force from axle housing to steering knuckle, turning 38" and larger tires in conditions that would negate the force from a power steering box.
If a guy wants to believe a power steering box is superior in ways besides its neat little packaging that's their prerogative.
