biggest tires to fit '10 E350? - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 04-01-2011, 11:56 AM
Killer RC's Avatar
Killer RC
Killer RC is offline
Killer RC is starting off with a positive reputation.
I found a sweet deal on some 275/70R18 tires. Anybody know if they will fit a 2010 E350 without rubbing? Not sure if it will clear the front bumper when turning.
Old 04-01-2011, 12:25 PM
Killer RC's Avatar
Killer RC
I think thats a 33" tire. My stockers are 30.4". I doubt they will fit.
Old 04-02-2011, 07:44 AM
JWA's Avatar
JWA
JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
That large a diameter tire would be more likely to contact the rear of the fender well opening up front. I run 245/R75-16 Michelin's and they're very very close. I'd love to use the 265's but not sure if they'd rub.
Old 04-02-2011, 07:55 AM
Killer RC's Avatar
Killer RC
Is yours a E350? I wish I could put a simple 2" lift on the front to make room for tires but my van has RSC and I've been told that messing with the suspension makes the RSC computer act up and can affect the antilock brakes.
Old 04-02-2011, 08:49 AM
JWA's Avatar
JWA
JWA is offline
Sorry Killer---mine is just an E250 with stock suspension---I might have jumped in too quickly!!
Old 04-02-2011, 06:30 PM
Killer RC's Avatar
Killer RC
I think the E250 and 350 probably have about the same ride height.
Old 04-03-2011, 01:05 AM
SilverE350's Avatar
SilverE350
SilverE350 is offline
SilverE350 is starting off with a positive reputation.
You can run 265/75 16's (31.5") stock if your springs aren't sagged. You can also raise the van, but putting a kit with a drop pitman arm in there will cause the RSC to act up. Spacer blocks for an F 350 up to 2" will work or Super Coils or TTC 2814 Coils will raise it as well.
I've put the TTC2814's in my 2008 with RSC and run 265/75 16 Nitto's without a problem.
Old 04-03-2011, 01:15 AM
Killer RC's Avatar
Killer RC
Great info. Thanks.
I might do these. http://maxx-lift.com/e250-e350-2wd-l...it-2-inch.html
Old 04-03-2011, 01:33 AM
SilverE350's Avatar
SilverE350
Originally Posted by Killer RC View Post
Great info. Thanks.
I might do these. 1999 2011 E250 E350 ECONOLINE VAN 2WD FRONT LEVELING KIT
Wow, I've looked all over the place and that is the first time I saw those. Thank you!
Old 04-03-2011, 01:37 AM
SilverE350's Avatar
SilverE350
Old 04-03-2011, 03:41 AM
Killer RC's Avatar
Killer RC
Yeah, I think I'll order those spacers. I'll post pics.
I have almost the same van as you. Silver 2010 E350 12 passenger 5.4L. You got any good pics of your van and wheels/tires?
I just got telesoping towing mirrors and a Super Duty grille from a F250. I have an 18' enclosed car hauler trailer to pull, and ya know most of these vans don't have tow hitches, so last week I ordered a custom Reunel rear bumper with hitch, painted to match the van. I got a pioneer z130bt nav head unit and rear view camera on the way too.
Old 04-03-2011, 10:38 PM
SilverE350's Avatar
SilverE350
Here's a few:
Old 04-03-2011, 10:42 PM
SilverE350's Avatar
SilverE350
As you lift the van, the I Beams swing down. Notice the relationship between the center X member and I Beam. You loose ground clearance here while gaining elsewhere.
Old 04-03-2011, 11:24 PM
Killer RC's Avatar
Killer RC
Is your front lifted? It looks lifted in that pic with the white wheels.
Old 03-19-2013, 08:19 PM
rebar13
rebar13 is offline
rebar13 is starting off with a positive reputation.
thread resurrection
Subscribed on this one.. Mines a 95 cargo e350
From what Iv read and see.. a 265/75-16 is max.. on front.
How about on the rear? I wouldn't mind going a bit wider, only if I can keep the outside diameter the same since I want to convert it to 4x4
Quick Reply: biggest tires to fit '10 E350?
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
