welcome to the your an April FOOL thread.....
Anybody think this is a good cooler? I am thinking of yanking both of mine and starting new to see if I can get my temps down.
Heavy Duty Transmission Cooler NEW!!!
That is pretty close to the same one I added to my V10. I am not overly impressed, but I have way more stock cooling than you, so who knows.
Did not read far enough the first time Jay.
If you already have the V10 cooler like mine, than with that Hayden I saw 10-15 deg drop towing. Now I never saw a reading much over 120 over outside air temp with the stock unless in the mountains. I would sit at about 170 with an outside air of 80, and that is while towing the 5er. Over the mountain passes I did see 225 deg in 60 deg air, but that was a 10-12% grade for 6 miles and I was running in low gear and rpm at 3500, but it did help it cool off quicker once I started to descend the other side.
I was not overly impressed, but my camper is heavier than yours and I have than lowly gas engine.
The one thing that I disliked about having added it is it takes forever for the trans to heat up when really cold. I hardly drive it in the winter so it is not a huge deal.
I installed mine like Dave told me too, so If I remember correct it goes through the stock V10 cooler first than into the Hayden.
You can certainly try the spare that I've got and see if it fixes your problem.
#29
Good morning Jay! I am not sure on that cooler. You have the v10 cooler along with the factory one if I remember correctly. Your cooling should be about the same as mine and Mike's trucks so I am thinking your only upgrade would be the 31 row 6.0 cooler or possibly adding a third cooler like Cory is running.
