Our 1995 f350 powerstroke would not start in park
A few days ago our truck would not start in park finally got it to when found neutral Today it would not start again so tried to in neutral but did not feel like I was in the right spot When had key on with foot on brake pedal could move the shifter to park and ect but seemed to skip some is there a simple fix for this that we can do. Thank you for any help
Thank you for the input. A friend stopped by today and he slowly moved the shifter till engine tried to start and was able to get it started. He then looked under and had me move the shifter slowly he was able to push a cable in some so now it will turn over in the park position. I was able to see the red needle move a bit so question now is how can we adjust it so stays where supposed to? Hubby is disabled but luckly he taught me to be a backyard mechanic so can do most basic things with his guidence
Would like to thank all of you for your help that was exactly what was wrong the 2 bolts were ready to fall out now can actually feel the 6 clicks while shifting from gear to gear.We bought our truck brand new has over 225000 miles and still turns heads when we go to the stores Have only had a few things go wrong but never totally left us stranded in 16 years. So thank you again for the photo, and size of torge as we had all we needed for the easy fix
