tire clearence
Old Dec 7, 2002 | 12:18 PM
plugugly's Avatar
plugugly
Post tire clearence
I have a 95 crew cab F150. 8" suspension lift with 35 inch tires, I need about two more inches of clearence. Does anyone have cut out fender flares on theirs. would like to see pics if possible. How much clearence can I gain with this. I would rahter not go with a body lift.
Old Dec 7, 2002 | 12:26 PM
mickelsons's Avatar
mickelsons
tire clearence
you have a '95 Crew cab F-150??? I have never heard of that. also I had a 6 inch lift on my F-150 super cab and had plenty of clearance for 35's what size tire are you planning on running?
Old Dec 7, 2002 | 01:15 PM
plugugly's Avatar
plugugly
tire clearence
It is a conversion done with a F350 cab, same people that did the vans for ford. I already have 35 inch tires, super swampers, 15inch 12.5 on it. When I turn sharp I have about an inch or less clearence on the front wheels to the rear of the fender opening. Any bump at all, like pulling into my drive way will cause it to hit.
Old Dec 8, 2002 | 12:20 PM
mickelsons's Avatar
mickelsons
tire clearence
Wow, I had a lot more clearance with mine and a 6" lift that is so weird.
Do you have any pictures of your truck? I would love to see it
Old Dec 8, 2002 | 01:15 PM
MustangGT221's Avatar
MustangGT221
tire clearence
The extra weight probably has something to do with it.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
Check out my Gallery for a look-see.
Justin - One Happy FTE Member
Old Dec 25, 2002 | 02:22 PM
plugugly's Avatar
plugugly
tire clearence
I believe my problem is the wrong tire size. i have 35x14.50 not 12.50x15. I am amazed that you guys dont rub with six inch lift and I have an 8 inch and do even with the wider tires.
Old Dec 25, 2002 | 08:51 PM
mooktank's Avatar
mooktank
tire clearence
I could be rubbing on the radius arms cuz mine do. I have a 6 inc suspension, 3 inch body and 36x12.5s
Old Dec 25, 2002 | 10:00 PM
plugugly's Avatar
plugugly
tire clearence
No I am sure it is hitting the fender I can watch it out the window. It is actually hitting where the fender skin curls over to meet the inner fender well. Right where that last bit of paint is and the crews that hold the inner fender well to the metal. i am sure that the 14.50 wide is the problem.
Old Dec 25, 2002 | 10:11 PM
steve83's Avatar
steve83
tire clearence
