Spare tire question....
Preparing the Excursion for a cross country road trip and making good progress going down my list. I've got new Michelins all the way around with the Discount Tire warranty if something comes up. I was checking my spare tire and it looks to be an unused Pirelli. I'm not sure if it is the original OEM spare or if it has been replaced.
I'm curious if I should chance it or get the piece of mind of getting a new spare. Cheapest tire Discount has in OEM size is $115 out the door. I would hate to get a flat, then put the spare on and have more problems.
Opinions?
edit... looked up how to find the date code and the tire is from 2007. That's still 7 years of being inside in the sweltering heat of Texas...
Opinions?
First of all, good choice on the Michelins.
Secondly, I had this exact dilemma about 4 months ago. My spare was the original factory tire (manufactured in late 2004). It looked perfect upon inspection, but my gut was telling me to replace it because of age. I'm not one to roll the dice with my whole family on the side of a highway at night... If I lost one of my tires, I wanted something to get me moving that I KNEW I wouldn't have a problem with further down the road.
My advice is to replace it now and be done with it and have peace of mind.
Also, my spare was not Pirelli..... so not sure if yours was original or not.
James
James
on
Opinions?
Opinions?
Oops I just saw your last post but I wouldn't have changed it.
I think you are over-thinking it. You might as well get another plastic tub and fill it full of spare parts. That spare will be fine, mine is 14 years old but I invested in a little plugging kit, 2 cans of suv size fix-a-flat, and a little cig lighter air compressor. I also carry a few tools and an extra fan belt.
I can't argue with him wanting to ensure that all is right and will work if needed. Props to him on ensuring that he is ready. As for me, maybe it's time to check that old spare, even though using it on my Ex would be like using a doughnut tire on a small sedan.
That was the right move I just had 5 Michelin MS2's installed. My spare was from 2005 it looked perfect but once you load it up it could go at any time. Michelin puts the life expectancy at 6 years so I guess they would probably be good for 8-10 but I would use when you would be replacing the tires again.
on
something to remind yourself on journeys, that I have to remind myself. If you forget something, or something happens it's modern day and most places can help you. Very few towns don't have a mechanic or in this case a tire shop. If I blew tire I'd be happy "limping" it to a shop on my 10 year old spare to get my other tire fixed or replaced. The spare can be an old tire, your not doing the journey to south america or such.
UV light and wear age tires, sitting covered in the truck it would last a long time for the purpose of getting you to a shop and out of danger on the side of a road. It's more important to insure it has air in it.
You might not be able to loosen the lug nuts on your own too, remember that. I always travel with AAA. But in the times you might be away from cell coverage you do need to know how to change a tire. Practice in your driveway if you have never done it.
on
I agree ^^ and I think that guy that replaced his spare was too careful and wasted some money. As for the nuts being too hard to get off; I change my wheels every winter and put grease on the studs and tighten them with my electric impact, and no nay-sayers because I have been doing it for 50 years. I have never had to use a spare and that guy might as well have towed a little trailer full of tools and parts.
Totally agree... what do you think they did with that tire you gave them Perfectly good tire, no flat spots, no wear... I would have sold it to a friend or kept it for myself!
Gee, I wonder who made that app? Could it be the tire companies? Mobil should put out a change your oil every 10 minutes app, there's a sucker born every minute
I always remember my shop teacher saying put a bit grease on the threads, but never on the cone part of the lug nut. It hydro locks and over time the grease may dissipate, lowering the torque or having the nuts come loose. Just something in case it is read by others to put grease all over it or such.. They should be dry in the cone part only.
on
I too run winter tires and summer tires, so they are off a lot. I want them torqued when I drop it off.
