Mouse nest behind passenger battery. Using the battery insulation to make a nest! Anyway, they also chewed off insulation on a green wire with red tracer that is just a short wire (2 inches) that is looped in a connector that plugs into harness behind the battery. Anyone know what this connector is? I repaired the wire with a new wire and heat shrink but curious to what this connector is for.
