wheres your brake controller?
Hey I'm thinking about where I'm gonna put myh brake controller...anyone have any pics of their instal? I think ill be going the tekonsha prodigy route (my other 2 are the best!) Pics and details on where the pigtail plugs in under the dash would help too, thanks!
Her is a link to a video of an install in an 07. I followed this and I'm happy with the location. I did not put the second screw in and it has not moved a bit.
Trailer Brake Controller Installation - 2007 Ford Expedition Video | etrailer.com
I did not drill my dash either. There are a couple screws that hold the dash on above the brake pedal and gas pedal. I chose to use the one over the brake pedal. It took me about 5 minutes to install mine, it already had the ford adapter attached. One screw removed from the dash, re-insert screw with the adapter bracket, plug in wire harness then make sure you get the rest of the cord out of the way and you are good to go. I do agree that an integrated controller would be awsome.
67xr7kat
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
02-16-2020 09:02 PM
Gravesdigger
16
09-01-2012 08:36 PM
Tym
1999 to 2016 Super Duty
22
02-02-2006 07:36 AM
04, 2000, 2005, 2010, 2011, box, brake, controller, expedition, ford, integrated, lincoln, navigator, plugin, putting
