ford 460. i want more hp. what to do?
After that it all starts costing more $$$!
Here are a couple good links on 460 EFI's
HEDMAN Headers on a 460EFI, 5spd https://www.ford-trucks.com/forums/1...headers-2.html
460 EFI headporting and dyno results https://www.ford-trucks.com/forums/9...ts-are-in.html
96 is EFI, not carbed
FULL tune up, remove the air horns in the intake tubes (if still there) and a full true dual mandrel bent tubing exhaust with headers, and a smog pump delete (provided you do not have to go thru smog testing). If you have to go thru smog, you will need to do a cat back system.
For a budget of 2k:
Exhaust (as mentioned above)
K&N air filter (cold air kits are nice but not necessary)
Tune up
headers
Roller rockers (if available)
Dyno tune
I think more than this would cost you more $$$$$, but if you are into DIY, and you wanted to port a little, I start with the exhaust ports because they are always a little restrictive, and then if you wanted look at the intake and possible port match to the intake. You could also look check the throttle body entrance as well.
HEADERS CHROME FORD 1988-1997 TRUCK/CLASS A MOTORHOME/CLASS C MOTORHOME, 460 F.I., 2/4WD, NO Y-PIPE, WITH SMOG FITTINGS at Doug Thorley Headers dougthorleyheaders.com
Gibson Performance Exhaust - Trucks, SUV, Diesel, RV, and Marine. Performance Exhaust for the Enthusiast
