Sprung Door? 1949
  #31
Old 04-05-2018, 01:17 AM
Suffolkman's Avatar
Suffolkman
Suffolkman is offline
Suffolkman has a good reputation on FTE.Suffolkman has a good reputation on FTE.
Originally Posted by topmoo View Post
A 1/2" at the bottom could change pretty dramatically with a small amount of tweeking at the hinge. Similar to pivoting a 20" stick/board/piece of anything a 1/16" at one end - the other end will move much more than 1/16".
Just to be clear, when you say tweaking the bottom hinge, do you mean the rubber mallet between door and frame, or actually trying to adjust the hinge ?. Also I have been thinking if I want to get the bottom of the door in,then maybe I should try and bend the top of door out ?.
  #32
Old 04-05-2018, 09:29 AM
topmoo's Avatar
topmoo
topmoo is offline
topmoo has a superb reputationtopmoo has a superb reputationtopmoo has a superb reputationtopmoo has a superb reputationtopmoo has a superb reputationtopmoo has a superb reputationtopmoo has a superb reputationtopmoo has a superb reputationtopmoo has a superb reputationtopmoo has a superb reputationtopmoo has a superb reputation
Suffolkman you are right, I thought you were talking more about the gap which is 2 plane up and down. Not sure the Ford shop manual process will help with what you have. Sounds like your door is warped probably due to a past wreck with either a warped door or a cab problem. Good luck with it.
  #33
Old 04-05-2018, 09:41 AM
F1 coyote
F1 coyote is offline
F1 coyote has a very good reputation on FTE.F1 coyote has a very good reputation on FTE.F1 coyote has a very good reputation on FTE.
Every F1 I've come across has this problem, the pass. door shuts tight while the driver door hangs out an eighth to a quarter inch. I think it has to do with all the flex in the stock frames, you just don't realize how much the frame twists up on the right side especially with a more powerful engine. Look at the margins where the lower fenders meet the rails just behind the bumpers, most of the f1s' I've looked at have different gaps from one side to the other, all this due to frame flex. This in my humble opinion of course.
  #34
Old 04-05-2018, 11:48 AM
Cougar54
Cougar54 is offline
Cougar54 has a good reputation on FTE.Cougar54 has a good reputation on FTE.Cougar54 has a good reputation on FTE.
My observations are the same. I just get it as close as possible and then leave it.
gasman6674
Indiana Chapter
37
05-02-2016 08:53 AM
85F250Diesel
04-10-2016 04:38 PM
rojoraider
15
01-20-2016 03:15 PM
mic91F150
19
12-26-2015 05:53 PM
baumst
11-10-2015 08:00 AM
Quick Reply: Sprung Door? 1949
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
