How to quiet down door noise when opening doors?
Hi,
When I open the doors there is click-CLACK! Sound, seems to come from the plastic thing that gets into the door that prevents it from opening too much.
I have used grease and oil but nothing, still makes that CLACK! Sound.
Anthony ideas on how to make it more quiet?
thanks
thanks
The "plastic thing" is called a Door Detent & sounds as if u need to replace it
I've replaced mine, but not because they were bad. There are modified versions (see link below) & I highly recommended them! Whatever Ford engineer decided the doors opening distance on the 09-14 body style, needs to be kicked in the sack hard!
These will make your life much better
Door Detent 3.0 by northlight labs | Now F-150 Doors Open Just Right
1994FordF-350MegaCab
02-14-2019 04:16 PM
