gasket issue?
gasket issue?
should i be changing head or intake gaskets?
i have a 2000 F150 4.2L V6 that gets, on a good day, 13 mpg in town. at about 2700-2800 rpm, 65+mph in 4th, just before the 5th gear upshift, i can hear valve clatter.
is this a sign?
other info: 70,000 miles, 3.55 open axle, 245/75R16 goodyear kevlar mudders, leer camper on a shortbed regular cab. only mod is the gotts mod, which made no difference i can see. i do carry a good set of offroad recovery tools, but i'd be surprised if it was as much as 500 pounds. this truck has the heavy duty payload and towing packages.
it threw a code a while back, which was some vacuum valve on the intake or something like that. i wiggled a connector and the code went away. I recently replaced the fuel pump and its relay.
what do you guys think?
is this a sign?
i hope not! we must be talking about two different things. what we (me, anyway) call pinging, or knocking, is properly called preignition, and is bad; it can result in a hole in the piston. not good.
valve clatter, on the other hand, as i understand it, comes from the valve train itself, that mechanism on top of the head. it can be a problem, but unless a valve drops, the damage is limited to the valve train and a poor running engine.
i think.
i think.
good idea!
however, depending on how you meant it, i'm not sure i agree on "backing off the throttle" - as i see it, this stops pinging like "not driving" stops accidents. the problem is still there, you're just staying away from the situation. as i understand it, pinging, or preignition, is an incorrect operating condition, even if it's just bad gas, it needs to be corrected. it can be avoided, as you suggested, but that's not a fix. anyway, I'm going to try the high octane fuel, so if it is preignition rather than in the valve train, i should see a difference. I'll let you know, and thanks for the help!
73 ford guy
03-19-2023 04:38 PM
Coresair
33
06-22-2016 06:00 AM
jrobie79
Modular V8 (4.6L, 5.4L)
04-01-2016 12:15 PM
