Adding 2 Stroke oil to fuel?
Old 03-24-2011, 09:03 PM
CptSD's Avatar
CptSD
CptSD is offline
Is anyone doing this in their 7.3? I just heard of this and wondering if it is agood idea? I currently use the Ford additive (red cap) in about every other tank.
Old 03-24-2011, 10:22 PM
Franko72's Avatar
Franko72
Franko72 is offline
Molon Labe
Yep, been doing 1/2 to 1 oz walmart supertech 2 stroke per gal diesel for almost two years now.
It helps lubricate the fuel system, and quiets the injectors a bit.
Old 03-25-2011, 07:08 AM
riverrat41's Avatar
riverrat41
riverrat41 is offline
I do the same with the 2-cycle.I add some Diesel Kleen gray as well.
I think it works and have been doing it a long time.
Old 03-25-2011, 07:51 AM
Mike F250's Avatar
Mike F250
Mike F250 is offline
I was amazed how much it affected my injector noise. I have not been running it through the winter. Just didn't know if sub-zero would have any affect.
I have an FRx on the way so I'll wait to add it until after the FRx is installed. Just to see what the FRx changes...
Old 03-25-2011, 10:24 AM
kccatpower's Avatar
kccatpower
kccatpower is offline
i use it during the warmer months, i had a bunch of suzuki cci 2stroke oil left over when i switched from a rm250 to a rmz450.
Old 03-25-2011, 12:00 PM
BillyBob69's Avatar
BillyBob69
BillyBob69 is offline
Hmmmm I have alot of 2 stroke oil for my chainsaw and leg dicer, (Gas powered weed whacker).
I have heard alot of good things on this, but I have also seen a couple of people claiming no good. I wouldn't mind trying this if it didn't cause any issues.
Old 03-25-2011, 12:31 PM
RedBoat's Avatar
RedBoat
RedBoat is offline
Rather Be Floatin
I use 1 oz per gallon every other tank. No I'll effects and it does quite it down quite a bit.
Old 03-25-2011, 12:57 PM
BillyBob69's Avatar
BillyBob69
One ounce per gallon? That would be about 38OZ...isn't that alot?
Old 03-25-2011, 01:17 PM
RedBoat's Avatar
RedBoat
RedBoat is offline
Rather Be Floatin
I put in 1qt (32oz)per tank, since its a Short bed that comes out to about 1oz per tank. I do it every other tank.
Is that too much, I dont know for sure but it seems to have been working well and I have been doing it for the past 2-3 years.
Old 03-25-2011, 01:27 PM
F-250 Super Duty's Avatar
F-250 Super Duty
F-250 Super Duty is offline
I dump a quart in the tank every fill up!!!
Old 03-25-2011, 03:26 PM
bigbubba87's Avatar
bigbubba87
bigbubba87 is offline
I run one ounce per gallon. And half ounce per gallon of diesel kleen.
Old 03-25-2011, 04:22 PM
hammer65's Avatar
hammer65
hammer65 is offline
I have been adding a Qt of ATF at fill up. I have a 38 Gal tank and have been putting in around 25 gal @ fill up.
I think it quiets the engine down.
Old 03-25-2011, 06:04 PM
bcaughhorn's Avatar
bcaughhorn
bcaughhorn is offline
I think I will try this out too
Old 03-25-2011, 06:59 PM
Franko72's Avatar
Franko72
Franko72 is offline
Molon Labe
It helps to replace the missing lubrication that the Ultra Low Sulfer Diesel is missing these days.
Here is a chart that compares some of the alternatives.
Check number 7.
Old 03-25-2011, 07:12 PM
megawatt00's Avatar
megawatt00
megawatt00 is offline
I cant find it here in the local Walmarts. I have been wanting to try this one out for a while.
Quick Reply: Adding 2 Stroke oil to fuel?
