help, trailer brakes locked up when plugged in
well i grabbed the blue wire that wasn't connected (brilliant right!!), switched the brake and aux connection and wow! the controller lights up, pulled the trailer down the driveway and it turns to red when hitting the brakes, i can definitely feel them grab.
now to adjust the brake gain and level tomorrow.
thanks all- REPS SENT TO ALL!
Glad you fixed it! Set the level so the line on the **** is vertical even if the controller is angled, then pull the trailer and slide the lever and if it locks reduce the gain, if the trailer tires don't lock increase it until you feel the trailer tug on you. By doing this you are setting the maximum braking the trailer brakes will provide, like I said earlier the voyager is inertia based.
Happy towing.
Happy towing.
dawhits1
29
07-07-2021 08:27 PM
Pigseye
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
07-29-2017 07:07 AM
Franko72
15
04-14-2009 07:33 AM
