7.3L Fuel Pump
WELCOME TO FTE!!!!
Here are some links you SHOULD save!:
1994.5 - 1997 7.3L Power Stroke Diesel - Ford Truck Enthusiasts Forums
http://pages.prodigy.net/stevebaz/_i...az/index3.html
1996 Bronco/F-Series Workshop Manual
97-15A 7.3L DI Turbo Workshop Manual
Now that is out of the way, The Banjo bolt goes back in the same way. Sorry I can't tell you anything else. Blood, Sweat and beers! Someone else may be able to soften the blow with another way. It could be worse! You could have a Cali model.
Again WELCOME TO FTE!!!
WELCOME TO FTE!!!!
X2 on the welcome a board.
One thing that will help is to run the bolt in & out of the pump a few times to make sure the threads are clean . As was said , grease on the second washer .. BTW , the washers should be new ...
John Wall
06-18-2017 09:59 PM
Tugly
04-12-2017 07:38 PM
andrewjdouglas
29
07-08-2016 01:09 PM
truckman87
31
05-10-2011 10:12 PM
Powerstroke-7.3
13
12-29-2009 02:45 PM
