460 exhaust manifold cracked
I have a86 e150 motorhome that the rear of the passenger exhaust manifoold is cracked and it looks like someone has brazed it. I have heard that this is a common problem with these. My question is, what is the best fix? replace the manifold with a new one,(where can I get one) or if I take this off can I get a welding shop to fix this one. thanx.
There are nickel electrodes designed for welding cast iron with an arc welder.I was able to fix my own quite easily using an ordinary AC welder so any good welding shop shouldn't have any problem.But most likely by the time you have it fixed you would be approaching the cost of one of the ebay ones, so that might be a better option.
Resendiz
05-28-2015 05:55 PM
axehandle
08-26-2013 10:33 AM
