Another Power Steering Problem Story 06 F350..
Ok heres my story, steering has lately been getting kinda notchy acting like it was indexing while turning. No whine, smooth, just @ highway speeds while taking sweeping turns and some lane changes.. I have worked on this trucks front end many times and have had 33's,35's and 37's mounted up, truck would always turn the wheels lock to lock @ idle on concrete or blacktop. Anyways took truck in before extended warr ran out and had gearbox and pump replaced. Now indexing is gone but steering is really hard and it wont turn 35's on concrete or even dirt @ idle. All front end parts are fairly new and mercon syn was used after install per shop. So my question is why would truck have turned so effortlessly before the new parts and now i have the dreaded hard steering.. Parts were installed less than a week ago and seems to be getting worse, steering wheel will not turn tires while stopped.....thanks
Received 5,128 Likes
on
^^ Good call , thats what i 1st thought.
With all the work 2 the front end the steering damper may be set up in the wrong position , bent or damaged.
Try taking the damper off and see if it makes a difference.
Wheels off the ground it will turn, took off dual stab (even though it worked fine before) still wont turn with whels on the ground. Balljoints and all front end parts are fairly new again worked fine before parts installed. Does not matter @ idle or raised idle neutral or park, wheels dont turn.. Took in for nocthy steering but it was smooth, parts changed and now terrible harsh steering... could it be a bad pump ? wrong oil ? bad gearbox ? i am @ wits end with this, wish i could just put the old parts back on and try a flush...
on
on
annaleigh
18
01-14-2017 01:08 PM
AGrayson84
1997-2006 Expedition & Navigator
10-08-2016 08:16 AM
jplinville
19
09-26-2016 04:07 PM
Doc Juju
06-25-2016 02:26 PM
M-S-G
05-24-2016 08:11 PM
