What is it worth???
Hard to tell with the limited information you provided.
But here's as close as I could get. It must be worth more then this! lol
1999 Ford F150 Super Cab - Private Party Pricing Report - Kelley Blue Book
yes, see that's what I keep coming up with:
here is more:
Leather Interior, Front Seats Do have Small Tears and show Normal Wear.
- CD/DVD In -Dash TV
- HID Headlights and Foglights
- Crystal Clear Headlights and Foglights
- Running Boards
- Soft Toneau Bed Cover
- Mobil 1 Synthetic Oil and Filter Used at Every Oil Change
- All Fluids Recently Flushed with BG Service with Records to Show
*Includes* Brake Fluid, Power Sterring Fluid, Transmission Fluid, All Anti-Freeze, Oil and Engine Clean, Air Intake and Fuel System Clean, Transfer Case Fluid Changed, Rear End Fluid Changed, Chassis Lubed.*
- All Synthetic Fluids
- New General Grabber Tires with less then 15,000 miles on them
- 20% Window Tint on Front Windows to Match the Back
- Sliding Rear Window
- 4 Door Ext. Cab
- 4 Wheel Drive
- Turn Signal Mirrors
- Trailor Brakes
- Towing Package
here is more:
- Running Boards
- 4 Door Ext. Cab
- 4 Wheel Drive
- Trailor Brakes
- Towing Package
I cant find a listing on there for the 7700 package.
Dose it have the 4.6 or 5.4?
I added in a few more options and the 5.4 But still cant find the 7700.
It bumped the price up some but it still looks low for that truck in good shape.
Who is selling it? A private party or a dealer?
Look at post #11 in this thread. This guy payed 9K for a 99 ,3 years ago.
https://www.ford-trucks.com/forums/1...l#post10122431
thanks
and you are so right
checking it out tomorrow - gotta say seller has been very upfront !
See below: direct quotes:
1. The wiper switch activates sometimes causing the wipers to come on going down the road at times. Switch works fine and wipers always work when you turn them on they just seem to randomly sweep when the switch isnt on sometimes as well. When I had the truck serviced at xxxx Ford I was told the switch needed to be replaced. I priced the part and its cost is 70bucks. <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
2. Tears in the seats, all the foam is in tact just has a few tears in leather, if you would feel more comfortable before seeing it in person I can send pics. <o></o>
<o></o>
3. Valve Cover has a slight seep and you can see a bit of grease from the oil, this isn't a major leak and xxxx Ford said it was normal and I could replace the Valve Cover Gaskets for about 50bucks. <o></o>
<o></o>
4. Rear Main Seal leaks, has a slow drip of oil. Told by xxx Ford of problem and the cost for the part is about 30bucks. The labor for the replacement is about 800 though. <o></o>
<o></o>
5. Odometer works and counts fine but the backlight on it doesn't always light up so you cant always see the mileage. Truck is about to trip 132,000 very soon.<o></o>
<o></o>
6. There is now a small hole in the front grille where a box flew up going down the road. I have a new grille on the way for it though.<o></o>
<o></o>
Other then that there are no problems with the truck.
see anything that SCREAMS problem??? I am having my mechanic check out tomorrow
<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
<o></o>
