2004 F150 4.6L Transmission question Help please - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
Reload this Page >
Old 03-19-2011, 11:02 AM
JB_85F150's Avatar
JB_85F150
JB_85F150 is offline
JB_85F150 is starting off with a positive reputation.
Okay, let me start off with I did use the search options and couldnt really find my exact issue.
I just bought a 2004 F150 STX 4.6L V8 with automatic trans with 57,000 miles.
I love the truck. However, I just noticed yesterday that in heavy traffic at very low speeds (constant stop and go at low speed between 10 and 20 mph) that the truck at one point seemed to slip out of gear.
In other words, it seemed like the truck shifted into neutral just revving when pressing the gas (again, this was at a very low speed so I dont think it was OD problem like I read about) The truck did not show a check engine light or anything. Once I let the truck rev settle back down, I was able to drive it again. I've had the truck for about a week now and this has been the only time it has happened.
Any ideas? Has this happened to anyone else? Any help or tips?
**when using the search option, I read in several places that the 5.4L truck having a similar issue, but with the trans going into neutral just before shifting into OD. So I dont think my problem is related since mine is a 4.6L and it only happened once and that was at a very low speed as mentioned above**
Any help or advice is greatly appreciated
thanks,
Josh
Old 03-19-2011, 12:23 PM
dgndngrngr84's Avatar
dgndngrngr84
dgndngrngr84 is offline
dgndngrngr84 is starting off with a positive reputation.
Josh I would check a few things. Check the dipstick when the truck is hot idling in park after driving a few miles. See if the fluid looks dark or smells like its burning. Make sure the fluid isn't low. If the fluid it hasn't been changed which I bet it hasn't it's due. I bought mine at 45,000 miles (now have 75,000) and I've noticed that between 20-30 mph the truck slips out of 4th and into 3rd sometimes but I don't notice a loss of power.
Old 03-19-2011, 07:08 PM
JB_85F150's Avatar
JB_85F150
i drove the truck not long ago . it prob sat for about 15 mins. it was still warm so i pulled the trans dipstick and smelt it. i dont really know what burnt fluid actually smells like but it smells okay i guess. u could tell the fluid smelt warm but i dont think it smelt burnt. however the level seemed kind of high. the fluid was above the hot level marking in the do not add marking. the fluid looks new too. i bought the truck at a dealership so it looks they servised it new oil, trans fluid, etc. etc. could the level being high cause the prob? the truck has not done it again but its still in my mind.
Old 03-19-2011, 07:36 PM
Millzy
Millzy is offline
Millzy is starting off with a positive reputation.
The fluid should be checked hot and with the engine running. I would contact the dealer since you just bought it and see if the transmission had been recently serviced. If it has been serviced there is a possability that the filter is not seated properly.
Old 03-19-2011, 09:15 PM
dgndngrngr84
Millzy's right, the reason it needs to be idling when you check it is so the pump is operating which will drop the fluid on the stick a bit. Yeah you should check to see if they have it on record of the change at the dealer. If it only happened that one time I wouldn't worry about it unless it comes back. If the dealer didn't change it I would at least drop the pan, change the filter and replace the 5.5 quarts. Or you could do the system flush method after replacing the filter, adding the 5.5 qts and getting the rest out of the cooler lines on the front, just for the peace of mind.
Here is a link for info on the flushing method if you want to do it yourself: https://www.ford-trucks.com/forums/6...-schedule.html
Old 03-19-2011, 09:35 PM
Fox Fader's Avatar
Fox Fader
Fox Fader is offline
Fox Fader is starting off with a positive reputation.
Bad tranny fluid may not necessarily smell burnt, it can have a sour/bad odor.
Old 03-20-2014, 11:21 AM
Harrisons Ford's Avatar
Harrisons Ford
Harrisons Ford is offline
Harrisons Ford is starting off with a positive reputation.
Is it possible to syphon tranny fluid out through the dipstick tube and replace with fresh fluid?
Old 03-22-2014, 08:01 AM
60DRB's Avatar
60DRB
60DRB is offline
60DRB has a good reputation on FTE.60DRB has a good reputation on FTE.
Yes.
Many of us "home mechanics" install drain plugs or replace the pan with one that has a drain. That makes future fluid changes less messy...and thus, more likely to occur.
Old 03-22-2014, 07:11 PM
pdqtimetrialer's Avatar
pdqtimetrialer
pdqtimetrialer is offline
pdqtimetrialer is gaining momentum as a positive member of FTE.
Every once in a while mine truck seems to slip between 2nd and 3rd gear for a brief second. I also have a slight misfire when idling. No check engine light. Haven't put a scanner on it yet. Could a misfire effect the shifting?
Jimmy Pet
Modular V10 (6.8l)
17
05-10-2017 11:46 AM
trex777
2004 - 2008 F150
06-23-2016 12:58 PM
1 Wheel Drive
2004 - 2008 F150
12-10-2015 11:26 PM
kper05
1997 - 2003 F150
05-27-2012 04:45 PM
1958
11-13-2008 12:28 PM
Quick Reply: 2004 F150 4.6L Transmission question Help please
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
